Chick broody box temperature monitor
by DiamondNix on Tue Mar 21, 2017 9:24 pm
I took the temperature/humidity sensor from the Ada Box 003 and made a wireless temperature sensor to monitor my new chick in her broody box.
Thanks Ladyada! ;)
DiamondNix
Re: Chick broody box temperature monitor
by adafruit_support_mike on Tue Mar 21, 2017 11:47 pm
Neat! Thanks for sharing!
by Groundcoffee on Fri Jan 18, 2019 11:01 am
I am trying to do the same but i am getting this error
Arduino: 1.8.7 (Mac OS X), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Enabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from sketch/config.h:1:0,
                 from /var/folders/qh/ytwk6hbj7dlbbq9p1ntl3k4w0000gn/T/arduino_modified_sketch_328344/adafruitio_15_temp_humidity.ino:19:
/Users/denverlopes/Documents/Arduino/libraries/Adafruit_ESP8266/Adafruit_ESP8266.h:28:35: error: section attribute not allowed for 'Pchr'
 typedef const PROGMEM char        Pchr; // Ditto, kindasorta
In file included from /Users/denverlopes/Documents/Arduino/libraries/ArduinoHttpClient/src/ArduinoHttpClient.h:8:0,
                 from /Users/denverlopes/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO.h:23,
                 from /Users/denverlopes/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_ESP8266.h:18,
                 from /Users/denverlopes/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO_WiFi.h:32,
                 from sketch/config.h:23,
/Users/denverlopes/Documents/Arduino/libraries/ArduinoHttpClient/src/HttpClient.h: In member function 'virtual void HttpClient::flush()':
/Users/denverlopes/Documents/Arduino/libraries/ArduinoHttpClient/src/HttpClient.h:310:50: error: return-statement with a value, in function returning 'void' [-fpermissive]
     virtual void flush() { return iClient->flush(); };
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
Groundcoffee
by kcl1s on Fri Jan 18, 2019 11:23 am
It is hard to troubleshoot without the code but it looks like you have 2 errors listed
1 It does not like the way you used PROGMEM. Here is an article on using it on the 8266 https://arduino-esp8266.readthedocs.io/en/latest/PROGMEM.html
2 Looks like you are trying to return a value from a function with void. You need to precede the function name with the variable type you are returning.
Fellow hobbyist
Keith
kcl1s
