PyPortal issue - no USB drive for circuit python or uf2 prog
by paks on Tue Apr 02, 2019 9:48 pm
I'm having issues with the PyPortal that came with Adabox 011. The portal
starts but doesn't show a disk drive when connecting to the computer. I have
tried different cables and computers and no luck so far. I have other Circuit
Python devices and they show the disk drive when connecting to the computer.
I also double clicked the reset button and the neopixel in the back turns
red and no disk drive either. Also, there is not serial port detected. I
tried the arduino app, but with no serial port available, I cannot reprogram
the pyportal. All the solutions that I find in the forums assume that a disk drive
will show up in the computer. Again, I have tried different computers (two
macbook pro and a Windows 10 machine). Different cables that work (Disk
Drive shows up) when connecting a Circuit Playground Express device. What
else can I do?
Cesar
paks
Re: PyPortal issue - no USB drive for circuit python or uf2
by adafruit_support_carter on Mon Apr 08, 2019 7:11 pm
Hey, sorry it's not working nicely. Can you clarify what you mean by "it starts". Does it show anything on the display when you power it up?
by paks on Thu Apr 11, 2019 4:44 pm
When the PyPortal starts, it shows the default app that came preinstalled.
paks
by adafruit_support_carter on Thu Apr 11, 2019 8:19 pm
OK, so it's not something fundamental like a bad power supply. And it's running what it came loaded with, so it's working to a point. It really seems like a USB cable issue, but you've tried several - including one(s) that are known to work with other boards.
See if any of the known issues here apply in your setup:
https://learn.adafruit.com/welcome-to-c ... n/overview
by paks on Sun Apr 14, 2019 10:54 pm
I read the troubleshooting section about issues with antiviruses and other programs. I used a Windows 10 machine with only malwarebytes. In that machine, I get the following error dialog when I connect the pyportal:
paks
cron
