Odd Matrix Portal Behavior -- Data Signal Corruption or Powe
by brendanm720 on Fri Nov 20, 2020 6:13 pm
Quick Question -- My Matrix Portal and LED Matrix from AdaBox 16 has developed some odd behavior.
When it's handled, the top half (with the Matrix Portal off to the right side) will change colors (e.g. cyan turns green, white turns red or yellow). It goes away if I fiddle with the Matrix Portal and place it in exactly the correct place.
Any ideas where I should start troubleshooting?
-Brendan
brendanm720
Re: Odd Matrix Portal Behavior -- Data Signal Corruption or
by dastels on Fri Nov 20, 2020 9:24 pm
Sounds like a connection issue. Inspect the soldering on the matrix connector (on the portal).
Post a clear photo if you can for more eyes on it.
dastels
by brendanm720 on Mon Nov 23, 2020 9:47 am
Thank you, Dave. I'll have a look at it and report back.
Also, something I've noticed is there is some "play" in the plastic part of the connector on the back of the matrix portal... I'm not sure if that has any bearing on anything or not.
Thanks again!
brendanm720
