Macreopad with line in the center of the OLED
by _vckymrtll on Wed Jul 28, 2021 12:11 am
Hello everyone,
Has anybody seen issues were lines appears on the OLED display?
It does not look like to be dead pixel, any ideas if there is a way to fix it?
Thank you,
_vckymrtll
Re: Macreopad with line in the center of the OLED
by _vckymrtll on Wed Jul 28, 2021 12:22 pm
When I rotate the macropad display, to 180 the bottom line disappears, but the middle one is still present. Is this a bad OLED? I tried the nuke UF2 and multiple releases of circuit python 7.0x and got the same result.
_vckymrtll
by adafruit_support_carter on Wed Jul 28, 2021 3:33 pm
What was the most recent version you tried here?
Try downloading and running this ready to go demo UF2 file:
https://learn.adafruit.com/adafruit-mac ... -3100141-2
as another way to test if the OLED shows the glitch. You run it just like installing CP firmware - just drag UF2 to the RPI-RP2 folder.
by _vckymrtll on Wed Jul 28, 2021 5:56 pm
Hi, thank you for the reply.
I wanted to add that this glitch was there out of the box.
I just tried the latest alpha 5 and with the suggested demo. I got the same result. :( the line only shows vertically.
Screenshot 2021-07-28 144534.png (398.47 KiB) Viewed 152 times
_vckymrtll
by adafruit_support_carter on Wed Jul 28, 2021 6:15 pm
Hmm. OK. What about if you trying running the UF2 file?
by _vckymrtll on Wed Jul 28, 2021 6:38 pm
That’s exactly what I did.
- I Tried alpha 5: same results.
- Then I tried the UF2 file: same issue(this is the image on my previous reply
Best,
_vckymrtll
by adafruit_support_carter on Wed Jul 28, 2021 7:05 pm
Thanks for verifying. Wanted to make sure this wasn't something related to current development of CircuitPython for the MacroPad. The UF2 is the good sanity check for that.
So, yah, seems like maybe that OLED has an issue. It's actually possible to replace it on the MacroPad. If you flip the MacroPad over, you'll see the ribbon cable going into a little connector. And the OLED itself is just held down with double-backed tape. We can send you a replacement OLED if you think you'd be OK doing the swap out?
by _vckymrtll on Wed Jul 28, 2021 8:08 pm
I will be okay doing the swap of the OLED of my MacroPad if you send me a replacement one :).
I took a look at the ribbon cable, and I notice some marks on it, but does not look like is a cut on the cable, and I'm unsure this could be the reason for these glitches. Reseating the cables did not make a difference :(
_vckymrtll
by adafruit_support_carter on Thu Jul 29, 2021 11:24 am
OK, cool, let's get you a replacement OLED and see if that works. Send an email to support@adafruit.com with a link to this thread and ask them to send you a new OLED display for the MacroPad.
by _vckymrtll on Thu Jul 29, 2021 11:23 pm
Sent!
Thank you so much for the support hopefully the replacement OLED display will resolve my issue.
_vckymrtll
by adafruit_support_carter on Fri Jul 30, 2021 12:17 pm
That's the hope :)
You can respond back here after you get the replacement if it still doesn't work or you have questions about installing it, etc. But fingers crossed that it'll work.
by _vckymrtll on Thu Aug 19, 2021 8:51 pm
I just wanted to circle back and confirm that the replacement part resolved the issue. No more glitches on the OLED screen :)
_vckymrtll
by adafruit_support_carter on Fri Aug 20, 2021 10:27 am
Awesome. Thanks for letting us know. Glad that fixed it and thanks for doing the repair work with the replacement OLED. Have fun!
