Funhouse won't control items on A0 and A1 at same time
by diggee17 on Wed Oct 06, 2021 5:22 pm
I'm recreating an Adafruit funhouse project that I found in a Make magazine from last year. It is supposed to control a micro server on pin A0 and a 30 LED strip on A2. It can control the LED strip best alone. It struggles to control the servo alone but It will NOT control both the servo and the strip together at all. As shown in the code I’m including, I have changed the number of pixels to 10 but that hasn’t helped.
I don’t have a Stemma Micro Servo. So I’m using a regular micro servo connected to A0 via a a female-female wire connected to a stemma male connector that I received in the Funhouse Adabox. Is this the problem is this too long of a connection?
I’m attaching picture of physical setup.
picture of funhouse with items attached
Code below:
import time
import board
import pwmio
import neopixel
from adafruit_motor import servo
from adafruit_funhouse import FunHouse
from adafruit_datetime import datetime, timedelta
funhouse = FunHouse()
pixel_pin = board.A2
num_pixels = 10
pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=0.05, auto_write=False)
pwm = pwmio.PWMOut(board.A0, duty_cycle=2 ** 15, frequency=50)
my_servo = servo.Servo(pwm)
def color_chase(color, wait):
    for i in range(num_pixels):
        pixels[i] = color
        time.sleep(wait)
        pixels.show()
    time.sleep(0.1)
RED = (255, 0, 0, 0)
YELLOW = (255, 150, 0, 0)
GREEN = (0, 255, 0, 0)
CYAN = (0, 255, 255, 0)
BLUE = (0, 0, 255, 0)
PURPLE = (180, 0, 255, 0)
WHITE = (255, 255, 255)
OFF = (0, 0, 0)
while True:
    if funhouse.peripherals.pir_sensor:
        my_servo.angle = 90
        time.sleep(1)
        color_chase(RED, 0.05)
        color_chase(YELLOW, 0.05)
        color_chase(GREEN, 0.05)
        color_chase(CYAN, 0.05)
        color_chase(BLUE, 0.05)
        color_chase(PURPLE, 0.05)
        color_chase(WHITE, 0.05)
        my_servo.angle = 0
        time.sleep(5)
    else:
        color_chase(OFF, 0.05)
        time.sleep(5)
Thanks.
diggee17
Re: Funhouse won't control items on A0 and A1 at same time
by dastels on Wed Oct 06, 2021 6:01 pm
First of all, what do you mean when you say it struggles to control the servo? What happens when you try to do both the servo and NeoPixels?
dastels
by diggee17 on Wed Oct 06, 2021 6:28 pm
thanks for your reply. The servo is supposed to move when you wave your hand in front of the PIR sensor. Also the neopixels should light up. I can get one action to happen but not both. Sorry if I wasn't clear.
diggee17
by dastels on Thu Oct 07, 2021 9:33 pm
I understand what you want to happen. But what exactly does happen? I'm still not clear on what "struggles to control the servo" means.
Maybe a video would help?
dastels
