Chassis slots where motors are supposed to mount are too short. The tab on the black bracket measures about .60, and the slot measures .48, assuming the brackets are correct width.
It wont fit without modifying either part.
BANNED
Adabox002 Chassis slots
Re: Adabox002 Chassis slots
[Moved to the ADABOX forum]
Please post a photo and indicate the slot you are referring to.
Those are not the motor mount slots. The motor mounting plates go inboard of the motors as in this photo:
https://learn.adafruit.com/tri-layer-mi ... all#step-3
The tabs on the plate fit into the pair of slots circled in the photo below:
- Capture.PNG (215.85 KiB) Viewed 672 times
- cherrick
THAT'S IT!
Thank you so much - problem solved.
Good to hear it is working for you now. With all those slots and holes, it confused me a bit the first time too.
