ADABOX 004 MUSIC PLAYER WITH IR REMOTE NOT WORKING
coolmandude545
Post by coolmandude545 »
Hi, I am trying to build the Music Player With IR Remote from Adabox 004, but when I push any button on the remote, nothing happens, Not even on the Serial Monitor! Does anybody know how to fix this?
dconley
Re: ADABOX 004 MUSIC PLAYER WITH IR REMOTE NOT WORKING
Post by dconley »
Did you pull the little bit of plastic out from the remote so that it's actually working?
Can you post a picture of your wiring?
What's your code? You could always try to write a simple program that prints any received IR code to the serial monitor.
coolmandude545
UPDATE: Okay, I got the board at least recognizing the remote, but when I push 1, 2, or 3, the board registers it but doesn't play the music. Is it a typo with the songs, or a SD issue?
cemclellan
Post by cemclellan »
Take a look at the code I posted in this topic - viewtopic.php?f=59&t=119535
It might help you out.
coolmandude545
I did see that, and it helped. I found out I named the songs wrong - I added ".mp3" at the end and the code wanted no ".mp3".
RIGHT:
track00?
WRONG:
track00?.mp3
Thanks to everybody who posted!
ASmart
Post by ASmart »
I am trying to upload the program for the IR remote but I keep on getting this. What should I do?
Arduino: 1.6.5 (Windows 8.1), Board: "Adafruit HUZZAH ESP8266, 80 MHz, 115200, 4M (3M SPIFFS)"
sketch_jul05b.ino:6:20: fatal error: IRrecv.h: No such file or directory
compilation terminated.
Multiple libraries were found for "SD.h"
Used: C:\Users\aryum\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Error compiling.
WARNING: Spurious .github folder in 'Adafruit Motor Shield library' library
enabled in File > Preferences.
Return to “AdaBox! Show us what you made!”
