Adabox004 streaming player with remote
by jcalvin on Tue Jul 04, 2017 3:51 pm
Was playing around with the streaming player and added the IR remote code to it. Then I needed something for the remote to do other than change the volume. So I added some code to read a list of internet streaming "stations" and allow CH+/- to switch between them. Code attached.
stations.txt file looks like (tab separated)
ice1.somafm.com /u80s-128-mp3 80
centova.orsradio.com / 8192
centova.orsradio.com / 8006
etc.
Since the SD card is there, it remembers the last volume setting and which station was selected.
18 Jul: Added check to see if connection died due to long pause or other reason. Restart stream if so.
WiFIPlayerv4.txt
(14.63 KiB) Downloaded 147 times
jcalvin
Re: Adabox004 streaming player with remote
by adafruit_support_mike on Wed Jul 05, 2017 12:52 am
Interesting.. thanks for posting it!
by ianm1 on Sat Jul 08, 2017 7:44 pm
This is great. Where did you get the port list of stations on OrsRadio? Can't seem to find it on their site.
ianm1
by jcalvin on Sun Jul 09, 2017 7:20 am
I didn't find a list either. But from the main page at http://www.orsradio.com/ click on one of the stations. A new page comes up that also does not show the port number. But if you click on the "listen in your favourite player" icons (I used the windows one) a small file will be downloaded that contains the URL and port number for that station.
Hope this helps.
jcalvin
by jwilfong on Mon Jul 10, 2017 2:33 am
Awesome! I was working on the same idea and saw you already did it!
Need to make a small change. The final station added cannot be accessed by pressing it's number. It is accessible using channel up and down but not by number. In the final if statement of your code change < to <=:
if (remoteNumber <= nextStationIDX) {
You also have the buttons of the remote defined at the top of the code but reference their values in the loop. Everything works but for readability change the test of lastRemoteValue to ....
if ( (lastRemoteVal == kRemoteVolumeUp) || (lastRemoteVal == kRemoteVolumeDown)) {
         code = lastRemoteVal;
It's also noteworthy that the last station in stations.txt must end with a CR/LF. Without it the code fails. I hacked together a test for the end of file to prevent this. It seems that this SD library can't be tested for -1 to indicate an end of file. Looks like you can test for ascii 207. Works for me, your mileage can vary. Last station in stations.txt can have CR/LF or it can be omitted and the code will run. I added the following if statement to the readToken procedure:
  char eofChar = 207 + '0';   // convert ascii 207 to char
  while (true) {
    theChar = stFile.read();
   if (theChar == eofChar) {    // check if end of file reached
       token[idx] = 0;
      return token;
jwilfong
by jcalvin on Thu Jul 13, 2017 2:11 pm
Thanks for the bug catches - fixed both as well as the case where I didn't use the defined constants.
jcalvin
by dconley on Fri Jul 14, 2017 9:29 am
One thing I noticed, which isn't a big deal but could be a learning opportunity, is that the code could be shortened a bit with modulo math.
currentStation = currentStation + 1;
if (currentStation >= nextStationIDX) {
    currentStation = 0;
You can change this to
currentStation = (currentStation + 1) % nextStationIDX;
This uses the remainder of dividing currentStation + 1 by nextStationIDX, which will be currentStation + 1 as long as it's less than nextStationIDX (1/4 is 0 with a remainder of 1), but 0 once it reaches the max! And if you somehow managed to jump 2 above the max (maybe pounding on the channel up button?) it would still translate into the second station (number 1). Think of it like a clock, with the hand starting over at 12.
Again: your code works fine, and I'm not trying to nitpick! But modulo is neat and I like using it.
dconley
by jcalvin on Fri Jul 14, 2017 12:01 pm
Thanks for the suggestion of using modulo math. It's fairly concise and probably generates a bit less code.
However, in this case (and most) I usually use the most obvious coding constructs to make it clear what I'm attempting to do (and like everything else it life, often fall short on this endeavor ;) . If I need to optimize for space or speed, I'll do that as necessary later, often leaving the original code in place, but commented out to help me remember what I was originally trying to do.
You'll also notice I don't even use the ++ and -- constructs. This partially due to my background, and partially due to my guess that some folks using Adafruit products may have different, or very limited, coding backgrounds. So I try to keep it somewhat obvious.
That said, it's a good construct for folks to know about and use.
Thanks for the comment!
jcalvin
by perrycannon on Sun Sep 17, 2017 6:09 pm
Can you post the stations.txt file? I have been searching for internet radio mp3 streams. Sites hide there path and host name.
Is it possible to use pls and m3u streams?
perrycannon
by jcalvin on Mon Sep 18, 2017 9:22 am
I've attached my copy of stations.txt. Streams seem to come and go a bit - my original list had half dozen from a site that now seems dead.
From my brief reading, m3u and pls seem to be playlist files rather than a stream. The contents of one of those files could be examined to get a stream address.
If you do a search for "mp3 stream lists" you'll find sources of streams. Sometimes it requires downloading a file and getting the actual stream address from within the file. Sometimes a little trial and error...
stations.txt
A few stations to try with WiFiPlayer
(260 Bytes) Downloaded 138 times
jcalvin
