Trouble with Transferring Roms
by larrybagina on Fri Sep 22, 2017 12:35 pm
The tutorial links to instructions for adding more roms to the Pi, but it doesn't seem to be working for me.
(ensure that your USB is formatted to FAT32)
first create a folder called retropie on your USB stick
plug it into the pi and wait for it to finish blinking
pull the USB out and plug it into a computer
add the roms to their respective folders (in the retropie/roms folder)
plug it back into the raspberry pi
refresh emulationstation by pressing F4, or choosing quit from the start menu
Nothing happens when I stick the usb stick into the Pi, no blinking of lights or acknowledgement or anything. Any ideas?
larrybagina
Re: Trouble with Transferring Roms
by velocipedal on Fri Sep 22, 2017 10:54 pm
Do you have a WiFi dongle you can use to connect the Pi Zero on your network? You could then see if you can SFTP the ROMs over.
velocipedal
by larrybagina on Sat Sep 23, 2017 8:39 am
Nope.
I'm in the process of a move so I'm reluctant to pick up more stuff in the meantime.
larrybagina
by yoada on Sat Sep 23, 2017 12:51 pm
I have Pi Zero connected to mac via usb cable, is there a way to see it in Finder to add more roms?
yoada
by velocipedal on Sat Sep 23, 2017 7:17 pm
Have you tried the manual copy option at the bottom of the page you linked?
velocipedal
by larrybagina on Sat Sep 23, 2017 7:41 pm
I tried it, but I don't currently have a keyboard (it's packed) so navigating the file manager is not something that is easy to do.
larrybagina
by jbwolf25 on Wed Sep 27, 2017 9:08 am
I have been unable to transfer ROMs as well. Following the procedure I see no blinking LED when I first plug in a USB. I have verified I am plugging it into the USB port and not the pwr in port. I tried going to the file manager, but that becomes unreadable if you try to work it without a keyboard. I did not see the USB mounted when it first comes up. Also on boot I see one fail, the line has "USB" on it. A line above that has a OK with a line of "USB" on it. I am not sure if that is expected on the PI that comes with the ADABOX.
jbwolf25
by Keebie81 on Wed Sep 27, 2017 10:44 am
sometimes rebooting the pi with the usb of roms in their correct folders plugged in helps also
Keebie81
by jbwolf25 on Thu Sep 28, 2017 8:33 am
The folders were not created yet by the pi yet. I did do some rebooting with the usb plugged in and this seemed to have helped.
jbwolf25
