Handheld gaming with adabox 005
by dearner on Sun Sep 24, 2017 6:55 pm
I ended up getting the 5" HDMI backpack from Digi-Key and thought it would be good for a handheld RetroPie + joy bonnet setup. So after a day or two of work, I've got a basic case that holds the screen plus the zero with an attached bonnet:
The biggest issue right now is that the cables that came with the adabox are somewhat too large to fit comfortably in a small case (so the cables have to come out the right side and back in the top). I've ordered some 1' cables and a thin anker battery, and am planning on redesigning it so everything fits in the case and the charging port for the battery is accessible. I should get that done this week, and am also planning on putting the completed design up on thingiverse.
dearner
Re: Handheld gaming with adabox 005
by sgarland413 on Wed Sep 27, 2017 11:39 pm
This is cool. I was thinking of doing the same thing. Where did you get the case? Also, any ideas how to get sound on it?
sgarland413
by dearner on Mon Oct 02, 2017 8:59 am
Hey,
I modeled and printed the case myself - I've been having trouble getting an HDMI cable that's got a small enough connector to fit entirely inside of it, though, so I've sort of put it on the back burner for the time being. As for audio, it looks like there's a guide here: https://learn.adafruit.com/introducing- ... io-outputs
dearner
by sgarland413 on Sun Oct 22, 2017 10:56 am
sgarland413
