⸮n?⸮$⸮!⸮⸮⸮⸮OCAC⸮⸮⸮⸮⸮⸮⸮O⸮⸮⸮
Please help me figure out what's wrong, I have not modified the sketch in any way and I made sure all of the board and components are assembled correctly.
The issue is, there is no other output. It just does that and stops. No other code running, no other output in the monitor, no sound from the board.adafruit_support_mike wrote:The first little burst of gibberish is normal.
The ESP8266's bootloader is burned in ROM, and it emits a short debug message at 74880 baud before it hands control to the code you've uploaded. That's an unusual baudrate, and the Arduino IDE usually sees the signals as nonsense.
If all of your output looks like that, not just the first line, it probably means you have a baudrate mismatch. Check your code's Serial.begin() statement to see what value it uses, and make sure the IDE's Serial Monitor is set to the same rate.
