Temp/Hum+Time/Date on a 32x16 Matrix
by robwlakes on Sun Jun 10, 2018 1:56 am
Hi Folks,
Thank you for the great 32x16 matrix display and Arduino interface shield. I have used an Arduino Uno with a 433MHz SuperHet Rx and an Oregon Scientific Temperature and Humidity Sensor (THGR122NX) to drive one of your matrix displays. Every 10 seconds it switches between showing Temperature and relative Humidity, and then Time and Date (takes day and month off the onboard RTC). I use a decoding system for the Oregon Scientific sensor that relies on delays to decode the protocol data packets. The timing just needed to be tweaked to allow for the time the display takes to multiplex the LEDs under interrupt and it works flicker free.
Edit: I need to add that I have no financial connection with Oregon Scientific, and if I was starting again I know I can build my own weather station from scratch with a 3D printer. I would build my ownfrom scratch, anemometer, wind vane and rain gauge https://www.thingiverse.com/thing:2849562.
You can get the code for this project plus some extra explanation here https://github.com/robwlakes/Weather_Matrix
This is picked up from an Oregon Scientific T/H sensor, over 433MHz, outside the building.
This is derived from the Adadfruit shield for the Matrix display as it also has an onboard RTC.
It has pride of place behind the bar at our local Tavern and shows the external temperature and humidity, 24/7. A nice conversation starter!
Cheers, Rob
robwlakes
Re: Temp/Hum+Time/Date on a 32x16 Matrix
by kcl1s on Sun Jun 10, 2018 7:27 pm
Cool project! Thanks for sharing.
Keith
kcl1s
