Hallowing screen goes blank
by rickseiden on Fri Sep 28, 2018 4:38 pm
I just got my Adabox and turned on my Hallowing. The eyeball looked around for a while, and then the screen went all white. I tried turning it off and on again, and resetting it, and it still just showed a blank white screen. I couldn't get the eyeball back. Then I plugged in into my computer and downloaded the human eyeball sketch to it, and now I have an eye again. But after a while, say about 2 to 3 minutes, the screen goes all white again, and I have to reset it or turn it on and off to get the eyeball back.
Is this expected behavior, or should that eyeball stay on the screen while it's powered on?
Rick
rickseiden
Re: Hallowing screen goes blank
by adafruit_support_mike on Fri Sep 28, 2018 11:14 pm
That's not how it's supposed to behave.
My first guess for a source of the issue would be a glitch in the power. What are you using as a power source for the Hallowing?
by Powderjockey on Sun Sep 30, 2018 4:01 pm
I too had this problem. I've been trying to follow along with the tutorials, but I'm still one with a black screen.
MU will not recognize the device (yes the cable is a data cable)
The scary Halloween script code.py will not run say there is an error in line 6, import board. I've placed the images on the device and they don't rotate thru.
I'm sure it is something very simple.
Scott
Powderjockey
by rsalamun6147 on Sun Sep 30, 2018 10:17 pm
Same issue screen blank and dark no sketch of the eye is playing. On back neopixel is fading green and small led is fluttering yellow on "charge" led. none of the video formats to upload work to submit what im seing on back neopixel of the board.
How I FIXED MY ISSUE:
Hallowing ships with a pre-loaded example of a human eye that looks around, blinks and reacts to light.
If you want to put the original spooky eye demo back on your Hallowing, (enter bootloader mode by double-clicking the Reset button and then drag this UF2 file over onto HALLOWBOOT:
There’s a few customized variants as well, such as a fiery dragon eye:
A brown, animal-ish eye with no visible sclera:
And a psychedelic eye from our Eye of Newt guide:
rsalamun6147
by Powderjockey on Mon Oct 01, 2018 11:13 am
Where did you get the uf2 file from? I've double clicked the reset button, long pressed the reset button and i can get both the HALLOWBOOT and CIRCUITPY disks to show up in Finder (Mac). But still don't get the spooky eye or any other image.
Powderjockey
by johnpark on Tue Oct 02, 2018 12:15 pm
The .uf2 files are available on this page: https://learn.adafruit.com/adafruit-hallowing/spooky-eyes
johnpark
by Powderjockey on Tue Oct 02, 2018 10:12 pm
Thanks John for the link. All four of the spooky eyes all work as expected.
But, I still can't get the Hallowing to work following the tutorial at https://learn.adafruit.com/motion-activ ... cuitpython .
Attached is what the circuitpy looks like. I'm not sure what I'm missing but, nothing shows on the screen. LED on the bottom (Back) cycles thru the colours and nothing else.
Powderjockey
by johnpark on Thu Oct 04, 2018 11:43 am
A very helpful thing to do when debugging trouble with a CircuitPython board is to look at the serial output to see what error messages are being created. If you're not familiar with using a serial console with HalloWing, check this out: https://learn.adafruit.com/welcome-to-circuitpython/kattni-connecting-to-the-serial-console and the REPL page https://learn.adafruit.com/welcome-to-circuitpython/the-repl
You'll need to use something like Screen on the mac or PuTTY on Windows, as Mu won't show the REPL/Serial console for HalloWing the way it does for other boards (CPX, Feather M0 Express, etc.)
I'm guessing there's either some errant typo in the code on your board or a missing library/mismatched library to CircuitPython version.
johnpark
by Powderjockey on Thu Oct 04, 2018 10:14 pm
This is the output of the Serial Console
soft reboot
code.py output:
  File "code.py", line 7, in <module>
ImportError: no module named 'displayio'
The code is from the tutorial and used the "copy code" to take it from the tutorial to the MU IDE.
Powderjockey
by Powderjockey on Fri Oct 05, 2018 12:46 pm
REPL output for modules
To list built-in modules please do `help("modules")`.
>>> help("modules")
__main__          adafruit_lis3dh   gamepad           samd
adafruit_bus_device/__init__        analogio          gc                storage
adafruit_bus_device/i2c_device      array             math              struct
adafruit_bus_device/spi_device      audiobusio        microcontroller   supervisor
adafruit_hid/__init__               audioio           micropython       sys
adafruit_hid/consumer_control       bitbangio         neopixel          time
adafruit_hid/consumer_control_code  board             neopixel_write    touchio
adafruit_hid/gamepad                builtins          os                uerrno
adafruit_hid/keyboard               busio             pulseio           ure
adafruit_hid/keyboard_layout_us     collections       random            usb_hid
adafruit_hid/keycode                digitalio         rotaryio
adafruit_hid/mouse                  framebuf          rtc
Plus any modules on the filesystem
I don't see anything for "displayio". Or would it not show up here?
Powderjockey
by Powderjockey on Mon Oct 15, 2018 8:51 pm
Been 10 days. any ideas on what I should be looking at. The hollowing_circuit just will not work. Spooky eyes seem to work just fine.
Is there an update to Circuit Python that I could load on the unit that might jump start things? I see it is Adafruit CircuitPython 3.0.0-rc.0-1089-g3700bc83b-dirty .
Powderjockey
by johnpark on Tue Oct 16, 2018 12:31 pm
The line in your serial output that says:
means that your HalloWing doesn't have the displayio library loaded onto it. I'm pretty sure this library is part of CircuitPython alpha 4.0.0 release, so maybe you don't have that version of CircuitPython on your board? https://learn.adafruit.com/hallowing-jump-scare-trap/code-with-circuitpython go to that page and download the CircuitPython .uf2 and then put your HalloWing in bootloader mode. Then drag on that .uf2.
johnpark
by Powderjockey on Tue Oct 16, 2018 7:55 pm
Thanks John,
took a couple of drag-n-drops, but it did finally start to work.
Now to complete the build.
Thanks again,
Scott
Powderjockey
by johnpark on Wed Oct 17, 2018 12:38 pm
Excellent, glad to hear it worked.
johnpark
