NeoTrellis M4 flash_erase fails
by mgorr on Thu Dec 06, 2018 9:21 am
I'm trying to erase the SPI flash on the NeoTrellis M4. I have cloned the latest Adafruit_SPIFlash from github, loaded the flash_erase example, and changed the FLASH_TYPE define to SPIFLASHTYPE_W25Q64, which I believe is the 8MB flash of the NeoTrellis. Is there anything else I'm missing?
Here is the output from the serial monitor
Adafruit SPI Flash Total Erase Example
Flash chip JEDEC ID: 0x0
This sketch will ERASE ALL DATA on the flash chip!
Type OK (all caps) and press enter to continue.
Erasing flash chip in 10 seconds...
Note you will see stat and other debug output printed repeatedly.
Let it run for ~30 seconds until the flash erase is finished.
An error or success message will be printed when complete.
Failed to erase chip!
mgorr
Re: NeoTrellis M4 flash_erase fails
by mgorr on Fri Dec 07, 2018 2:35 pm
I figured it out. I downloaded the QSPI library. Reading the tutorial helps...
mgorr
