Electronic Billboard for N Scale Model Railroad
Re: Electronic Billboard for N Scale Model Railroad
adafruit_support_mike wrote:Awesome! We'd love to see photos of the billboard once it's in your layout!
adafruit_support_bill wrote:Nice!
Note that it s possible to separate the display from the PCB if that is getting in they way of your modeling. They are attached with a bit of double-sided adhesive tape and can be removed with some gentle prying. You will need to use extra care once they are separated since the flex-connector between them is rather delicate.
Disciple wrote:I'm interested in pictures, too. My dad used to collect.
One point you probably already know, if the OLED will be displaying its graphics over the long term, a good idea might be to design those graphics with varying colors and layouts to avoid burning patterns into the grid. I've seen damaged store display TVs where that precaution wasn't taken.
Best of success. I bet we'll see an Adafruit billboard. (c:
adafruit_support_bill wrote:Longer wires are going to be more susceptible to noise, crosstalk and other interference. The clock and data pins are probably the most sensitive.
You could try wiring the clock and data lines as twisted pairs to help reject noise. Ethernet cable is a good source for nice tightly twisted pairs. Use one pair for SCK and GND. And use another pair for SDA and GND.
adafruit_support_bill wrote:That is a perfectly reasonable solution. DST is subject to change at the whims of legislators, so software solutions are only good until the rules change
if you actually go 10 scale miles you'd fall off the edge of the world LOL
