📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
PyPortal Weather Station issue
Re: PyPortal Weather Station issue
by kevinjwalters on Mon May 20, 2019 2:37 pm
Turns out there is a summary of the adafruit_pyportal library NeoPixel status colours on Adafruit PyPortal - IoT for CircuitPython: PyPortal Hardware FAQ: What does the status NeoPixel indicate once my code.py is running? The listed colours are a bit different...
I also noticed the library problem, explanation from Discord:
sommersoft: @kjw yeah. Travis deployment to GitHub had a hiccup. Service side, not ours (that i can tell). i'm hoping it runs today so i can see what's up. EDIT: here is the specific ded message:
/home/travis/.rvm/gems/ruby-2.4.1/gems/octokit-4.6.2/lib/octokit/response/raise_error.rb:16:in `on_complete': POST https://uploads.github.com/repos/adafru ... 190517.zip: 502 - Error updating policy (Octokit::BadGateway)
kevinjwalters
by burns3 on Tue May 21, 2019 6:35 am
adafruit_support_carter wrote:You're right. Not sure why that is. Something must have broken with the build tools and the auto release. I've sent word.
Any idea when it will be fixed?
burns3
by kevinjwalters on Tue May 21, 2019 6:40 am
kevinjwalters
by burns3 on Tue May 21, 2019 6:58 am
kevinjwalters wrote:May 20, 2019 auto-release looks ok?
I was still looking at the May 17th for an update
burns3
by burns3 on Wed May 22, 2019 6:24 am
adafruit_support_carter wrote:One of the underlying libraries (ESP32SPI) can get stuck in an infinite loop if the return is not as expected. So, it may also be this:
https://github.com/adafruit/Adafruit_Ci ... /issues/11
or, if you haven't updated the library, you're missing this:
https://github.com/adafruit/Adafruit_Ci ... PI/pull/44
In the end, this did not fix my problem.
The PyPortal still sticks after a couple hours and stops updating.
burns3
by adafruit_support_carter on Wed May 22, 2019 10:31 am
The problem hasn't been fixed yet. The link above is to an on going discussion about the issue.
by burns3 on Fri May 24, 2019 6:44 am
adafruit_support_carter wrote:The problem hasn't been fixed yet. The link above is to an on going discussion about the issue.
The discussion seems to have ended. Anything else I can do to get this working?
burns3
by adafruit_support_carter on Fri May 24, 2019 11:49 am
The discussion is still open. It may have stalled a bit, but it's still on going. For now I think just restarting the program is your only option.
by burns3 on Fri May 24, 2019 10:16 pm
adafruit_support_carter wrote:The discussion is still open. It may have stalled a bit, but it's still on going. For now I think just restarting the program is your only option.
Well, that stinks. How do I return it?
burns3
by adafruit_support_carter on Tue May 28, 2019 12:38 pm
OK, some work was done over the holiday weekend. A PR was merged and tested and seems to have at least fixed the problem with some cases, like #11, which has now been closed:
Try updating to the 1.3.8 version of the library:
https://github.com/adafruit/Adafruit_Ci ... /tag/1.3.8
and see if that helps.
