๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
PyGamer not functional with battery
by cheech47 on Sat Jun 29, 2019 2:21 pm
Received my first Adabox yesterday, and there seems to be an issue with the PyGamer. I am able to get it to a bootloader if I eliminate the battery and use a very short USB cable to a powered USB switch (and the PC recognizes it). Under battery power as well as under USB power using a known good 5v 2.5A USB charger, the display does not light and all NeoPixels are red. Could I have a bad battery?
cheech47
Re: PyGamer not functional with battery
by johnpark on Mon Jul 01, 2019 11:20 am
Could you please take a clear photo of both sides of the PyGamer so we can have a look? That certainly sounds odd.
johnpark
by cheech47 on Mon Jul 01, 2019 9:37 pm
Back of unit powered on with battery only. LED next to USB connecter was pulsating red.
Powered on with battery only
With USB charger attached. Yellow LED was solid, red LED was pulsating. No change to front of unit, still red NeoPixels and dead screen.
cheech47
by cheech47 on Mon Jul 01, 2019 9:43 pm
Removed battery and plugging direct into PC USB port using short USB cable.
Windows picks up drive.
After taking these pics I was able to update the bootloader to 3.7.0 successfully, however that did not change any of the PyGamer's behavior.
I also tried plugging into PC USB with the battery, the unit fired right up into bootloader mode.
cheech47
by johnpark on Tue Jul 02, 2019 12:10 pm
OK, a lot of that behavior sounds consistent with having a healthy PyGamer but no software running on it other than the bootloader. It will only go to bootloader when plugged into a computer with a USB data cable, yellow light means charging, red pulsing LED and red NeoPixels will happen when it starts up before finding code to run. So, it sounds like maybe yours didn't get the .uf2 on it before shipping perhaps.
With it plugged into the computer and in bootloader mode, try downloading and then dragging the pygamer_test.uf2 file onto the BOOTLOADER drive as explained here: https://learn.adafruit.com/adafruit-pyg ... duino-test
If that works, yay! You should be able to run that from battery or USB power.
johnpark
by cheech47 on Wed Jul 03, 2019 8:18 pm
The test file works, so that's good. Where can I get a copy of the pre-loaded game?
cheech47
by johnpark on Wed Jul 03, 2019 9:44 pm
johnpark
