Adabox 11 Problems with PyPortal
by alphagenius on Thu Jul 18, 2019 5:17 pm
I am working on the project in Adabox 11 that is locate here: https://learn.adafruit.com/pyportal-you ... rs-display.
I have gotten to the last step and I am stuck. When my PyPortal runs, it displays the YouTube background and the labels but no content. After about a minute, the screen disappears, and I get the errors. I just do not know how to proceed. Here is what is printed on the screen:
Retrieving data...Reply is OK!
{'error': {'code': 400, 'errors': [{'reason': 'key Invalid', 'domain': 'usageLimits', 'message': 'Bad Request'}], 'message': 'Bad Request'}}
Traceback (most recent call last);
File "code.py" line 60, in <module>
File "code.py" line 50, in <module>
File "/lib/adafruit_pyportal.py", line 776, in fetch
File "/lib/adafruit_pyportal.py", line 773, in fetch
File "/lib/adafruit_pyportal.py", line 547, in _json_traverse
KeyError: items
Code done running, waiting for reload.
I hope someone can help me get this going.
alphagenius
Re: Adabox 11 Problems with PyPortal
by adafruit_support_carter on Thu Jul 18, 2019 5:52 pm
Based on the JSON response you got:
it looks like you are having issues accessing the YouTube API. Did you setup the token?
https://learn.adafruit.com/pyportal-you ... -token-5-5
[EDIT] Is this a separate issue?
viewtopic.php?f=59&t=154229
by alphagenius on Fri Jul 19, 2019 9:22 am
I found the problem. In the "secrets.py" file where I put my token key, somehow I had a space between the first single quote and the start of my key. Don't know how I managed that but anyway. Thanks for your help.
alphagenius
by adafruit_support_carter on Fri Jul 19, 2019 11:24 am
Yeah. Glad it was something simple.
