Trellis box CAD files
by Vishwarath123 on Fri Aug 16, 2019 11:25 am
Hi I am looking to make a custom box with the buttons and the trellis pad offered by Adafruit. I looked into the Github resources for the same, which are in STL format (non-editable) Can you point me to the appropriate CAD files for the tray, top and other components so that they are editable
Vishwarath123
Re: Trellis box CAD files
by adafruit_support_carter on Mon Aug 19, 2019 12:51 pm
The STL files are CAD files which you should be able to download and use in you CAD software, if it supports STL format.
Which specific file were you trying to download?
by Vishwarath123 on Mon Aug 19, 2019 12:55 pm
I am looking for a either .STEP or prefarably, Solidworks assembly
Vishwarath123
by adafruit_support_carter on Mon Aug 19, 2019 12:57 pm
Oh, I thought you had found the file but were having trouble using it.
Can you link to the specific Trellis box you are after. Is it from one of the guides?
by Vishwarath123 on Mon Aug 19, 2019 1:28 pm
Yes. Its a four by four array box that I found on Thingiverse https://www.thingiverse.com/thing:211447
Vishwarath123
by adafruit_support_carter on Mon Aug 19, 2019 1:33 pm
The files are here:
https://www.thingiverse.com/thing:211447/files
Are you not able to download those? In terms of file format - those are what is available.
by Vishwarath123 on Mon Aug 19, 2019 1:39 pm
I could only find STL files which are not easy to modify. Hence am looking for CAD models.
Vishwarath123
by johnpark on Tue Aug 20, 2019 12:47 pm
there's also a 123d file linked there, which is a CAD file. It can be converted to use with Fusion 360 and possibly some other software.
johnpark
