Monster M4sk + GridEye = eyes that watch you
by teejaydub on Thu Oct 03, 2019 10:02 pm
I'm working on making a skull that will look at you with glowing eyes.
The Monster M4sk has worked out great, and combined with the Grid-EYE infrared sensor breakout and a little firmware mod, the eyes track the center of a heat source pretty well.
I'm documenting the project on a new media site called Factr: https://factr.com/u/timothy-weber/halloween-skull. There is a little video there of the current status, and all the details if you're interested.
Thanks, Adafruit! This has been really fun so far!
teejaydub
Re: Monster M4sk + GridEye = eyes that watch you
by adafruit_support_bill on Fri Oct 04, 2019 5:38 am
Nice work! Thanks for posting it. :)
by johnpark on Fri Oct 04, 2019 12:31 pm
Very creepy, love it!
johnpark
by MarkInTexas on Sun Oct 06, 2019 1:58 pm
Thanks for posting I wanted to do something similar, will check out your approach.
MarkInTexas
by teejaydub on Wed Oct 16, 2019 3:27 pm
Thanks all! I made a guide for it over at https://learn.adafruit.com/monster-m4sk-is-watching-you.
teejaydub
by michaelmeissner on Wed Oct 16, 2019 11:11 pm
Rather than using a heat sensor, I thought about using a pair of PIR sensors on either side of the M4SK, and use it to move the eyes back and forth. I.e. if the left sensor detects something closer than the right sensor, the eyes would look left:
michaelmeissner
by adafruit_support_bill on Thu Oct 17, 2019 6:28 am
I thought about using a pair of PIR sensors on either side of the M4SK, . . .
That would probably work. But it would not be very responsive. PIR sensors are pretty sluggish - even when you dial the retrigger time down to a minimum.
I did something similar several years ago for some animatronic eyes using an array of 3 of the Sharp IR rangefinders. It worked reasonably well, but the GridEye gives you a lot more resolution in a tiny fraction of the volume.
by teejaydub on Thu Oct 17, 2019 9:08 am
Yeah, I didn't think PIR sensors would have the speed and sensitivity to get much verisimilitude, and then they usually have pretty large white hemispheres over them that would be a little hard to work into a skull.
I think you'd probably get the best results with a night-vision camera with face recognition - but that's more expensive and complicated (probably requires a separate Raspberry Pi to handle the recognition) and seemed more time-consuming.
So far the performance on this seems pretty good. I have yet to test it in the target environment - outdoors at night at about 2-4 meters - but I'm hoping "dark and cold" only enhances the contrast with a face.
teejaydub
by michaelmeissner on Fri Oct 18, 2019 2:38 pm
Interesting to know about the PIR sensors. Thanks.
michaelmeissner
