Below is the code I am running and the time zone is America/Los_Angeles
# SPDX-FileCopyrightText: 2020 ladyada, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
import alarm
import supervisor
import alarm
from adafruit_magtag.magtag import MagTag
# Change this to the hour you want to check the data at, for us its 8pm
# local time (eastern), which is 20:00 hrs
DAILY_UPDATE_HOUR = 20
# Set up where we'll be fetching data from
DATA_SOURCE = "https://api.covidtracking.com/v1/us/current.json"
DATE_LOCATION = [0, 'dateChecked']
NEWPOS_LOCATION = [0, 'positiveIncrease']
CURRHOSP_LOCATION = [0, 'hospitalizedCurrently']
NEWHOSP_LOCATION = [0, 'hospitalizedIncrease']
ALLDEATH_LOCATION = [0, 'death']
NEWDEATH_LOCATION = [0, 'deathIncrease']
magtag = MagTag(
url=DATA_SOURCE,
json_path=(DATE_LOCATION, NEWPOS_LOCATION,
CURRHOSP_LOCATION, NEWHOSP_LOCATION,
ALLDEATH_LOCATION, NEWDEATH_LOCATION),
# Date stamp of info
magtag.add_text(
text_font="Arial-Bold-12.pcf",
text_position=(10, 15),
text_transform=lambda x: "Date: {}".format(x[0:10]),
# Positive increase
magtag.add_text(
text_position=(10, 35),
text_transform=lambda x: "New positive: {:,}".format(x),
# Curr hospitalized
magtag.add_text(
text_position=(10, 55),
text_transform=lambda x: "Current Hospital: {:,}".format(x),
# Change in hospitalized
magtag.add_text(
text_position=(10, 75),
text_transform=lambda x: "Change in Hospital: {:,}".format(x),
# All deaths
magtag.add_text(
text_position=(10, 95),
text_transform=lambda x: "Total deaths: {:,}".format(x),
# new deaths
magtag.add_text(
text_position=(10, 115),
text_transform=lambda x: "New deaths: {:,}".format(x),
# updated time
magtag.add_text(
text_position=(245, 30),
line_spacing=0.75,
is_data=False
magtag.graphics.qrcode(b"https://covidtracking.com/data",
qr_size=2, x=240, y=70)
magtag.peripherals.neopixels.brightness = 0.1
magtag.peripherals.neopixel_disable = False # turn on lights
magtag.peripherals.neopixels.fill(0x0F0000) # red!
magtag.get_local_time()
try:
now = time.localtime()
print("Now: ", now)
# display the current time since its the last-update
updated_at = "%d/%d\n%d:%02d" % now[1:5]
magtag.set_text(updated_at, 6, False)
# get data from the Covid Tracking Project
value = magtag.fetch()
print("Response is", value)
# OK we're done!
magtag.peripherals.neopixels.fill(0x000F00) # greten
except (ValueError, RuntimeError) as e:
print("Some error occured, trying again later -", e)
time.sleep(2) # let screen finish updating
# we only wanna wake up once a day, around the event update time:
event_time = time.struct_time((now[0], now[1], now[2],
DAILY_UPDATE_HOUR, 0, 0,
-1, -1, now[8]))
# how long is that from now?
remaining = time.mktime(event_time) - time.mktime(now)
if remaining < 0: # ah its aready happened today...
remaining += 24 * 60 * 60 # wrap around to the next day
remaining_hrs = remaining // 3660
remaining_min = (remaining % 3600) // 60
print("Gonna zzz for %d hours, %d minutes" % (remaining_hrs, remaining_min))
# Turn it all off and go to bed till the next update time
magtag.exit_and_deep_sleep(remaining)
