Problem with the MAGTAG COVID Tracker
dsheeran
Post by dsheeran »
I keep getting the following error when running the COVID Tracker code as supplied. Please assist.
code.py output:
Connecting to AP homenet
File "code.py", line 35, in <module>
File "magtag.py", line 150, in add_text
File "adafruit_bitmap_font/bitmap_font.py", line 60, in load_font
ImportError: no module named 'pcf'
mikeysklar
Re: Problem with the MAGTAG COVID Tracker
Post by mikeysklar »
@dsheeran,
Can you show me the directory structure of your mounted drive? eg. /lib, /fonts, code.py etc. I would like to confirm that the font files are located under fonts and all of the PCF files are included. Of course make sure you are running the latest CircuitPython and matching libraries on your magtag.
Once ready, click the Download: Project Zip File link below in the code window to get a zip file with all the files needed for the project. Copy code.py from the zip file and place on the CIRCUITPY drive along with the fonts/ directory that contains the arial-bold-12.pcf font
If you're having difficulty running this example, it could be because your MagTag CircuitPython firmware or library needs to be upgraded! Please be sure to follow https://learn.adafruit.com/adafruit-mag ... cuitpython to install the latest CircuitPython firmware and then also replace/update ALL the MagTag-specific libraries mentioned here https://learn.adafruit.com/adafruit-mag ... ibraries-2
https://learn.adafruit.com/magtag-covid ... y?view=all
dsheeran
Post by dsheeran »
I've got it working now. I needed to update the libraries.
Return to “AdaBox! Show us what you made!”
