I've got a strange issue with the Magtag that came in Adabox 017. It worked with the Fortune-Telling code on it for a little while, but then the E-Ink display stopped working.
Things seem to work okay as long as I don't try to write anything to the e-ink display. When I do, the entire thing hangs up. I'm thinking that something has failed in a spectacular fashion. I pinged discord for some assistance in early February, but the things we tried didn't fix it.
I contacted support via email on March 12 and Stephaie asked me to create a thread here and advised me that it may be 1-2 business days until I received a response. I created one on March 12 entitled "Strange Issue with Magtag from Adabox 017" which was viewed a large number of times but not commented upon.
Here's what works:
- Wifi
- i2c (AHT 20 Temp/Humidity)
- Battery Voltage (magtag.peripherals.battery)
- Buttons
- Neopixels
- Buzzer
Strangely, the drive and the serial device still show up. The Circuitpython drive is working -- I can make changes to the files on the Magtag -- but when I try to connect to the serial device with puTTY, it does not show anything. Restoring the code on the Magtag to the original project that it shipped with does not fix things, and gives me all red Neopixels (which is what happens prior to displaying the Digikey logo).
Here is what I've already tried to get this fixed (in February 2021):
- upgrade the uf2 file to Circuitpython (6.1.0)
- upgrade the uf2 file to the beta version of Circuitpython (6.2.0 Beta 1)
- upgrade the bootloader using esptool (per the instructions in the learn guide)
- upgrade the libraries to the latest Circuitpython 6 code as of 2/1/2021
- erase the flash using esptool and reinstalling the bootloader via esptool
- erase the flash using esptool and flash the bin version of Circuitpython 6.1.0 via esptool
I have a 2nd MagTag that is working fine and
Is there anything else I should try? I've attached the serial output from the RX/TX pins on the back of the unit in case that helps.
If there is nothing else to attempt, please advise what additional steps we need to take.
Thanks in advance!
-Brendan
