FunHouse display accumulating glitches
by steveputz on Sun May 16, 2021 8:33 pm
Running the Adafruit_CircuitPython_FunHouse simpletest, the display starts clean, but accumulates an increasing number of "glitches" at random locations in the regions not being updated with new values.
Is anyone else experiencing this?
steveputz
Re: FunHouse display accumulating glitches
by adafruit_support_carter on Mon May 17, 2021 3:17 pm
Weird. Can you try also with this SelfTest UF2:
https://learn.adafruit.com/adafruit-fun ... st-example
It's written in Arduino, but you don't need to actually have Arduino installed. Just put the board in bootloader mode, same way as with CircuitPython:
https://learn.adafruit.com/adafruit-fun ... -3089489-6
and then copy the SelfTest UF2 over.
by jerryn on Mon May 17, 2021 3:20 pm
I see the same thing with the CircuitPython demo.
jerryn
by steveputz on Mon May 17, 2021 5:39 pm
As expected, I do not see glitches on the Arduino test program, only under CircuitPython.
I suspect it is a problem with the CircuitPython handling of the display (maybe timing or interrupts?).
Do you recommend we avoid CircuitPython and program with Arduino instead? -- disappointing, if so.
steveputz
by adafruit_support_carter on Mon May 17, 2021 7:20 pm
Thanks for checking. Just wanted to make sure it wasn't hardware related. It did not look like it, but wanted to verify.
Seems like something is happening with CircuitPython and we'll take a look into this.
by adafruit2 on Tue May 18, 2021 11:43 am
adafruit2
Site Admin
by paulritik_09 on Wed Aug 11, 2021 9:15 am
I have saw the same thing with the Circuit Python demo spicemoneylogin.in myfiosgateway.one
paulritik_09
by danhalbert on Wed Aug 11, 2021 11:25 am
Please try CircuitPython 7.0.0-alpha.5 or later, which has tried to fix this.
danhalbert
