On each keypress, the pressed key will light up the brightest, the orthogonally adjacent keys (up down left right) will light up less so, and the diagonally adjacent keys will light up a even less. This makes use of the fancy led palettes to light up from "cool" to "warm" as more presses are registered for that key. Over time, the keys "cool down" and eventually turn back off again. The OLED display updates with the value of each key less frequently than the neopixels simply for performance reasons.
Haven't decided what to do with the encoder for this just yet, maybe wipe the whole board up or down, not sure.
By far one of my top boxes, thank you!
import displayio
import terminalio
import time
from adafruit_display_shapes.rect import Rect
from adafruit_display_text import label
from adafruit_macropad import MacroPad
import adafruit_fancyled.adafruit_fancyled as fancy
MACROPAD = MacroPad()
MACROPAD.display.auto_refresh = False
MACROPAD.pixels.auto_write = False
# Set up displayio group with all the labels
GROUP = displayio.Group(max_size=14) # 12 keys + rect + app name
for KEY_INDEX in range(12):
x = KEY_INDEX % 3
y = KEY_INDEX // 3
GROUP.append(label.Label(terminalio.FONT, text='', color=0xFFFFFF,
anchored_position=((MACROPAD.display.width - 1) * x / 2,
MACROPAD.display.height - 1 -
(3 - y) * 12),
anchor_point=(x / 2, 1.0)))
GROUP.append(Rect(0, 0, MACROPAD.display.width, 12, fill=0xFFFFFF))
GROUP.append(label.Label(terminalio.FONT, text='', color=0x000000,
anchored_position=(MACROPAD.display.width//2, -2),
anchor_point=(0.5, 0.0)))
MACROPAD.display.show(GROUP)
GROUP[13].text = "Heatmap"
COUNTS = [0]*12
last_display = 0
last_cooldown = 0
CENTER_BUMP = 20
ORTHO_BUMP = 14
DIAG_BUMP = 7
GRAD = [(0.0, 0x000000),
(0.1, 0x000066),
(0.2, 0x009900),
(0.3, 0xAAAA00),
(0.5, 0xFF9900),
(1.0, 0xFF0000)]
PALETTE = fancy.expand_gradient(GRAD, 50)
while True:
if time.monotonic() - last_cooldown > 0.01:
last_cooldown = time.monotonic()
for i in range(12):
COUNTS[i] = max(COUNTS[i] - 1, 0)
color = fancy.palette_lookup(PALETTE, COUNTS[i]/256.0)
MACROPAD.pixels[i] = color.pack()
MACROPAD.pixels.show()
if time.monotonic() - last_display > 1:
last_display = time.monotonic()
for i in range(12):
GROUP[i].text = str(COUNTS[i])
MACROPAD.display.refresh()
EVENT = MACROPAD.keys.events.get()
if not EVENT:
continue
if EVENT.pressed:
COUNTS[EVENT.key_number] = min(COUNTS[EVENT.key_number] + CENTER_BUMP, 255)
if EVENT.key_number%3:
if EVENT.key_number>=3:
COUNTS[EVENT.key_number-4] = min(COUNTS[EVENT.key_number-4] + DIAG_BUMP, 255)
if EVENT.key_number<9:
COUNTS[EVENT.key_number+2] = min(COUNTS[EVENT.key_number+2] + DIAG_BUMP, 255)
COUNTS[EVENT.key_number-1] = min(COUNTS[EVENT.key_number-1] + ORTHO_BUMP, 255)
if (EVENT.key_number+1)%3:
COUNTS[EVENT.key_number-2] = min(COUNTS[EVENT.key_number-2] + DIAG_BUMP, 255)
COUNTS[EVENT.key_number+4] = min(COUNTS[EVENT.key_number+4] + DIAG_BUMP, 255)
COUNTS[EVENT.key_number+1] = min(COUNTS[EVENT.key_number+1] + ORTHO_BUMP, 255)
COUNTS[EVENT.key_number-3] = min(COUNTS[EVENT.key_number-3] + ORTHO_BUMP, 255)
COUNTS[EVENT.key_number+3] = min(COUNTS[EVENT.key_number+3] + ORTHO_BUMP, 255)
