Macreopad with line in the center of the OLED
_vckymrtll
Post by _vckymrtll »
Hello everyone,
Has anybody seen issues were lines appears on the OLED display?
It does not look like to be dead pixel, any ideas if there is a way to fix it?
Thank you,
_vckymrtll
Re: Macreopad with line in the center of the OLED
When I rotate the macropad display, to 180 the bottom line disappears, but the middle one is still present. Is this a bad OLED? I tried the nuke UF2 and multiple releases of circuit python 7.0x and got the same result.
adafruit_support_carter
What was the most recent version you tried here?
Try downloading and running this ready to go demo UF2 file:
https://learn.adafruit.com/adafruit-mac ... -3100141-2
as another way to test if the OLED shows the glitch. You run it just like installing CP firmware - just drag UF2 to the RPI-RP2 folder.
_vckymrtll
Hi, thank you for the reply.
I wanted to add that this glitch was there out of the box.
I just tried the latest alpha 5 and with the suggested demo. I got the same result. :( the line only shows vertically.
Screenshot 2021-07-28 144534.png (398.47 KiB) Viewed 727 times
Hmm. OK. What about if you trying running the UF2 file?
_vckymrtll
That’s exactly what I did.
- I Tried alpha 5: same results.
- Then I tried the UF2 file: same issue(this is the image on my previous reply
Best,
Thanks for verifying. Wanted to make sure this wasn't something related to current development of CircuitPython for the MacroPad. The UF2 is the good sanity check for that.
So, yah, seems like maybe that OLED has an issue. It's actually possible to replace it on the MacroPad. If you flip the MacroPad over, you'll see the ribbon cable going into a little connector. And the OLED itself is just held down with double-backed tape. We can send you a replacement OLED if you think you'd be OK doing the swap out?
_vckymrtll
I will be okay doing the swap of the OLED of my MacroPad if you send me a replacement one :).
I took a look at the ribbon cable, and I notice some marks on it, but does not look like is a cut on the cable, and I'm unsure this could be the reason for these glitches. Reseating the cables did not make a difference :(
OK, cool, let's get you a replacement OLED and see if that works. Send an email to [email protected] with a link to this thread and ask them to send you a new OLED display for the MacroPad.
_vckymrtll
Sent!
Thank you so much for the support hopefully the replacement OLED display will resolve my issue.
That's the hope :)
You can respond back here after you get the replacement if it still doesn't work or you have questions about installing it, etc. But fingers crossed that it'll work.
_vckymrtll
I just wanted to circle back and confirm that the replacement part resolved the issue. No more glitches on the OLED screen :)
Awesome. Thanks for letting us know. Glad that fixed it and thanks for doing the repair work with the replacement OLED. Have fun!
Return to “AdaBox! Show us what you made!”
