AdaBox 019 Macropad: Zoom hotkey code (Mac)!
blakbuzzrd
Post by blakbuzzrd »
So after eagerly assembling my Macropad from Adabox 019 last night, I read Phillip Burgess's hotkey guide at http://https://learn.adafruit.com/macropad-hotkeys. He suggests that we might share custom configuration files here in the forums. I searched but I didn't find any; so here's one I made for Zoom on Mac. Hope it’s useful to you!
NOTE: I put the "don't-wanna-accidentally-hit-this" keys away from the edges where possible, and color-coded things by general type. Audio keys are red, informational keys are yellow, video keys are blue, and window resizing etc. keys are white. Also, the second key in the first row is not commented, because of line length limitations; that key controls visibility of the floating control bar in Zoom.
Apologies if I screwed up something in this post. I just turned 50 last week, and this is the first time I've really tried to make something like this that runs on code. Learning is fun!
# MACROPAD Hotkeys: Zoom for Mac
from adafruit_hid.keycode import Keycode  # REQUIRED if using Keycode.* values
app = {  # REQUIRED dict, must be named 'app'
    "name": "Mac Zoom",  # Application name
    "macros": [  # List of button macros...
        # COLOR    LABEL    KEY SEQUENCE
        # 1st row ----------
        (0x800000, "Space", ["SPACE"]),  # Temporarily Unmute
        (0x202000, "Control", [Keycode.CONTROL, Keycode.OPTION, Keycode.COMMAND, "H"]),
        (0x800000, "Mute", [Keycode.COMMAND, Keycode.SHIFT, "A"]),  # Mute/Unmute Audio
        # 2nd row ----------
        (0x004000, "Video", [Keycode.SHIFT, Keycode.COMMAND, "V"]),  # Start/Stop Video
        (0x004000, "Camera", [Keycode.SHIFT, Keycode.COMMAND, "N"]),  # Switch Camera
        (0x004000, "Share", [Keycode.SHIFT, Keycode.COMMAND, "S"]),  # Screen Sharing
        # 3rd row ----------
        (0x202000, "ID", [Keycode.COMMAND, "2"]),  # Read Active Speaker Name
        (0x800000, "Record", [Keycode.SHIFT, Keycode.COMMAND, "R"]),  # Local Record
        (0x202000, "Capture", [Keycode.COMMAND, "T"]),  # Chat Screenshot
        # 4th row ----------
        (0x101010, "FullSc", [Keycode.SHIFT, Keycode.COMMAND, "F"]),  # Full Screen
        (0x101010, "MinWin", [Keycode.SHIFT, Keycode.COMMAND, "M"]),  # Minimal
        (0x101010, "Gallery", [Keycode.SHIFT, Keycode.COMMAND, "W"]),  # View
        # Encoder button ---
        (0x000000, "", [Keycode.COMMAND, "W"]),  # Close Current Window
adafruit_support_carter
Re: AdaBox 019 Macropad: Zoom hotkey code (Mac)!
Awesome. Thanks for sharing!
blakbuzzrd
So after some field testing on several client calls today, I discovered several things:
1. The "Temporarily Unmute" keymapping isn't functioning as desired. Working to fix that.
2. The Chat "Capture" function is a dumb waste of a key. Remapping!
3. The "ID" key also doesn't seem to do anything. Investigating.
No worries. Can just post the updated versions here :)
LarryGB
Post by LarryGB »
I would like to see a version for Win if possible. Or what would need to be changed in your config to accommodate MS PC? Would be happy to try to make one but not sure of the extra parameters are required/
LarryGB
Post by LarryGB »
My attempt at a Win version, what else do I need?
# MACROPAD Hotkeys: Zoom for WIN - LGB Jul 28 2021
    'name': 'Zoom for WIN',  # Application name
    'macros': [  # List of button macros...
        (0x800000, "-Space", ['SPACE']),  # Temporarily Unmute
        (0x202000, "Invite", [Keycode.ALT, "i"]), #Invitation
        (0x800000, "Mute", [Keycode.ALT, "a"]),  # Mute/Unmute Audio
        (0x004000, 'Video', [Keycode.ALT, 'v']),  # Start/Stop Video
        (0x004000, 'Camera', [Keycode.ALT, "n"]),  # Switch Camera
        (0x004000, "Share", [Keycode.ALT, "s"]),  # Screen Sharing
        (0x202000, "-ID", [Keycode.ALT, "2"]),  # Read Active Speaker Name
        (0x800000, "Record", [Keycode.ALT, "r"]),  # Local Record
        (0x202000, "Chat", [Keycode.ALT, "h"]),  # Chat Screenshot
        (0x101010, "FullSc", [Keycode.ALT, "f"]),  # Full Screen
        (0x101010, "-MinWin", [Keycode.ALT, "w"]),  # Minimal
        (0x101010, "Gallery", [Keycode.ALT, "w"]),  # View
        (0x000000, "", [Keycode.ALT, "w"]),  # Close Current Window
% working.
Another way to share these is submit a Pull Request to have them added to the Guide code. Here's an example:
https://github.com/adafruit/Adafruit_Le ... /pull/1664
But this approach does require having a Github account and knowing the general process for making Pull Request. So just sharing here in the forums is fine as well. It's pretty easy to just grab the code from here.
blakbuzzrd
So I've been digging a couple days, trying to figure out a single problem:
I can't figure out how to tell the Macropad what to do when a key is pressed and held. So, for example, in Zoom, you can temporarily unmute the mic by holding down the spacebar. In Chrome, you can hold down the spacebar and the screen will scroll.
My search on this so far has been futile, but I am a complete beginner, and just starting to wrap my brain around coding.
I suspect the answer lies implicit somewhere in the Macropad Tone guide, in the discussion of key events: https://learn.adafruit.com/adafruit-mac ... ropad-tone
If I'm missing an obvious resource, please feel free to say so.
Any tips?
blakbuzzrd
adafruit_support_carter wrote:Another way to share these is submit a Pull Request to have them added to the Guide code. Here's an example:
I will learn how to do this, and start doing it. Thanks!
Each key press generates two messages, one for when the key is initially pressed down and one for when the key is finally released. For the majority of cases, like with normal typing, these two messages happen in rapid succession. A "held" key would be one where the "pressed" message is sent, but not the "released" message (until sometime later). So it's just a matter of code, but maybe somewhat complex code, to watch for that pattern. Like have a timer that is zeroed when a key is "pressed" and then if a "released" message does not show up after a set period of time, then take the "key held" action. That's the general idea at least.
demsecure
Post by demsecure »
LarryGB wrote:I would like to see a version for Win if possible. Or what would need to be changed in your config to accommodate MS PC? Would be happy to try to make one but not sure of the extra parameters are required/
Not sure why, but the Zoom code you posted didn't work for me. Neither did the NumPad code provided by Phil. Any key I pressed would just give me a "code done running" message and make my keyboard think the ALT key was continually pressed.
I took a swing at an alternate:
# MACROPAD Hotkeys example: Universal Numpad
    'name' : 'Zoom', # Application name
    'macros' : [           # List of button macros...
        (0x0000FF, 'Mute', [Keycode.ALT, Keycode.A]),
        (0x0000FF, '', [Keycode.I]),
        (0x0000FF, '', [Keycode.ALT,]),
        (0x0000FF, 'Video', [Keycode.ALT, Keycode.V]),
        (0x0000FF, '', [Keycode.K]),
        (0x0000FF, 'Camera', [Keycode.ALT, Keycode.N]),
        (0x0000FF, '', [Keycode.ONE]),
        (0x0000FF, '', [Keycode.TWO]),
        (0x0000FF, 'End', [Keycode.ALT, Keycode.Q]),
        (0x101010, '', [Keycode.CONTROL, Keycode.SHIFT, Keycode.A]),
        (0x800000, '', [Keycode.ZERO]),
        (0x101010, '', [Keycode.POUND]),
        (0x000000, '', [Keycode.ALT, Keycode.Q])
Hope this helps someone.
blakbuzzrd
UPDATE: I realized that my difficulty with the hotkey macros (particularly when trying to set up "Temporarily Unmute" in Zoom or "Scroll Down" in Chrome) lay in a fundamental misunderstanding of how to use the HID keycodes. After a week of banging my head against the wall, success. When I get a second, I'll do the Github thing, but meanwhile, for any Mac users, here are the latest versions of my macro configs for Zoom, Slack, Spotify (desktop app) and Chrome.
Zoom:
    "name": "Zoom",  # Application name
        (0x000000, "Mute", [Keycode.COMMAND, Keycode.SHIFT, "A"]),  # Mute/Unmute
        (0x000000, "Record", [Keycode.SHIFT, Keycode.COMMAND, "R"]),  # Local Record
        (0x000000, "TempUM", [Keycode.SPACE]),  # Temporarily Unmute
        (0x000000, "Video", [Keycode.SHIFT, Keycode.COMMAND, "V"]),  # Start/Stop Video
        (0x000000, "AltCam", [Keycode.SHIFT, Keycode.COMMAND, "N"]),  # Switch Camera
        (0x000000, "Share", [Keycode.SHIFT, Keycode.COMMAND, "S"]),  # Screen Sharing
        (0x000000, "FullSc", [Keycode.SHIFT, Keycode.COMMAND, "F"]),  # Full Screen
        (0x000000, "Control", [Keycode.CONTROL, Keycode.OPTION, Keycode.COMMAND, "H"]),
        (0x000000, "Gallery", [Keycode.SHIFT, Keycode.COMMAND, "W"]),  # View
Slack (note: emoji kotkey not yet functional):
# MACROPAD Hotkeys: Slack for Mac
    "name": "Slack",  # Application name
        (0x202000, 'Unread', [Keycode.SHIFT, Keycode.COMMAND, 'a']),  # Unreads
        (0x202000, 'Reply', [Keycode.COMMAND, 'g']),  # Search
        (0x202000, 'Emoji', 'r'),  # Emoji Reaction
        (0x202000, 'New', [Keycode.COMMAND, 'n']),  # New Message
        (0x202000, 'Edit', [Keycode.COMMAND, 'e']),  # Edit Message
        (0x202000, '+File', [Keycode.COMMAND, 'u']),  # Add File
        (0x202000, 'Mute', 'm'),  # Mute
        (0x202000, 'Video', 'v'),  # Video Toggle
        (0x202000, 'Invite', 'a'),  # Invite List
        (0x202000, 'WS1', [Keycode.COMMAND, '1']),  # 1st Workspace in List
        (0x202000, 'WS2', [Keycode.COMMAND, '2']),  # 2nd Workspace in List
        (0x202000, 'Prefs', [Keycode.COMMAND, ',']),  # Preferences
Spotify:
# MACROPAD Hotkeys: Spotify for Mac
    "name": "Spotify",  # Application name
        (0x004000, "Play", [Keycode.SPACE]),  # Play
        (0x004000, "Back", [Keycode.COMMAND, Keycode.LEFT_ARROW]),  # Previous Track
        (0x004000, "Next", [Keycode.COMMAND, Keycode.RIGHT_ARROW]),  # Next Track
        (0x004000, "Vol +", [Keycode.COMMAND, Keycode.UP_ARROW]),  # Volume Up
        (0x004000, "Vol -", [Keycode.COMMAND, Keycode.DOWN_ARROW]),  # Volume Down
        (0x004000, "Min", [Keycode.COMMAND, "m"]),  # Minimize
        (0x000000, "", [Keycode.COMMAND, "w"]),  # Close Current Window
# Write your code here :-)
Chrome:
# MACROPAD Hotkeys: Chrome for Mac
    "name": "Chrome",  # Application name
        (0x000040, "< Back", [Keycode.COMMAND, "["]),
        (0x000040, "Reload", [Keycode.COMMAND, "R"]),
        (0x000040, "+Tab", [Keycode.COMMAND, "T"]),  # New tab
        (0x000040, "Copy", [Keycode.COMMAND, "C"]),
        (0x000040, "Paste", [Keycode.COMMAND, Keycode.SHIFT, Keycode.OPTION, "V"]),
        (0x000040, "Down", [Keycode.SPACE]),  # Scroll down
        (0x000040, "+Zoom", [Keycode.COMMAND, "+"]),
        (0x000040, "-Zoom", [Keycode.COMMAND, "-"]),
        (0x000040, "Incog", [Keycode.SHIFT, Keycode.COMMAND, "N"]),
            0x000040,
            "Ada",
            [Keycode.COMMAND, "n", -Keycode.COMMAND, "www.adafruit.com\n"],
        ),  # Adafruit in new window
            0x000040,
            "BGG",
            [Keycode.COMMAND, "n", -Keycode.COMMAND, "www.boardgamegeek.com\n"],
        ),  # BGG in new window
            0x000040,
            "Hacks",
            [Keycode.COMMAND, "n", -Keycode.COMMAND, "www.hackaday.com\n"],
        ),  # Hack-a-Day in new win
        (0x000000, "", [Keycode.COMMAND, "w"]),  # Close window/tab
Return to “AdaBox! Show us what you made!”
