adabox 19 micropad not showing up on the computer
- munocat
When I plug the micropad into my PC, Mac or Pi it does not show up as a drive. I am using the pink usb-c cable supplied in the adabox. any idea ?
- dastels
- munocat
Re: adabox 19 micropad not showing up on the computer
I was able to get the RPI-RPI2 drive to come up, still no drive when not in the bootloader mode
- munocat
I downloads the latest uf2 and installed it, it now shows up
- petronivs
I have a similar issue, and I am not able to get into bootloader mode. When I try, I get a pop up from windows that Windows does not recognize the USB device, and it shows up in Device Manager as "Unknown USB Device (Set Address Failed)".dastels wrote:Can you get into bootloader mode? See https://learn.adafruit.com/adafruit-mac ... cuitpython.
Any recommendations?
- petronivs
Update on this. After I read a different thread here that talked about underpowered USB ports, I tried a port on the back of my computer. (I had been using the more accessible ports on the front.) This time it worked, so that might have been the issue.petronivs wrote:I have a similar issue, and I am not able to get into bootloader mode. When I try, I get a pop up from windows that Windows does not recognize the USB device, and it shows up in Device Manager as "Unknown USB Device (Set Address Failed)".dastels wrote:Can you get into bootloader mode? See https://learn.adafruit.com/adafruit-mac ... cuitpython.
