Screen artifacts with CircuitPython
jskora
Post by jskora »
I am using CircuitPython 6.3.0 on the FunHouse and notice screen artifacts building up over time.
What am I doing wrong? Can I prevent this without full screen redraw each time through the main loop?
1. on startup
2. after ~30 seconds
3. after ~60 seconds
mikeysklar
Re: Screen artifacts with CircuitPython
Post by mikeysklar »
I had been getting a lot of artifacts on a OLED display with CircuitPython. After updating the bootloader, libraries and CP release eventually it stabalized and the noise stopped. If you are already currently on those then try the 7.x + 7.x libs as there has been some more display updates.
https://circuitpython.org/board/adafruit_funhouse/
jskora
Post by jskora »
I'm pretty sure I've been using 6.3.0, I will try 7.0.0.
ryanpavlik
Post by ryanpavlik »
I have also seen and posted about this as well, I think only on the FunHouse. (I had a similar long-running app on the Clue and I don't remember seeing it there) Good to hear 7.0 might fix it, I'll have to give that a try.
jskora
Post by jskora »
Yes, 7.0.0-alpha has fixed it.
Thank you!
mikeysklar
Awesome! Thank you for the confirmation.
Return to “AdaBox! Show us what you made!”
