MACROPAD 2+ Player "Chess" clock
macewmi
Post by macewmi »
If you've seen a video where people are playing chess, you've probably noticed a chess clock.
It's a way to ensure that games that involve a lot of "pondering" will end after a reasonable amount of time. During a player's turn, their clock is running. When they finish their move, they push a button which stops their clock and starts their opponent's clock. Play continues in this way. At the start of the game, each player is given a specific amount of time to beat their opponent. If they haven't beaten their opponent by within that time -- they lose.
My friends and family play games that require "pondering" but the games aren't limited to two players. To keep these games moving along, I used the MacroPad to build a "chess" clock for between 2 and 12 players.
Here's the flow:
  • Display a bitmap for a few seconds
    Prompt for the number of players. Use the encoder to dial-in the number
    Light that many pixels with a rainbow palette
    Prompt for the player who will make the first move. Again, use the encoder
    Push the encoder to begin play
    Repeat until the current player's time expires or someone wins
    • Turn off all keys and Illuminate the key of the current player only
      Display the current player's time remaining
      When the current player presses their key, move on to the next player
    ELSE
    • Display a humiliating "You lost"
from adafruit_macropad import MacroPad
import time
import colorLib  # Array of 12 colors
import toneLib  # Array of 12 tones
def clearDisplay(display):
    for line in range(10):
        display[line].text = " "
    display.show()
def lightNextPlayer():
    #OLED[0].text = "Player {}".format(currentPlayer + 1)
    macropad.pixels[currentPlayer] = colorLib.PALETTE[currentPlayer]
    # macropad.play_tone(toneLib.TONES[currentPlayer], 0.25)
    # macropad.play_tone(toneLib.TONES[5], 0.25)
    return time.time()
def showAllPlayers():
    for player in range(numberOfPlayers):
        macropad.pixels[player] = colorLib.PALETTE[player]
def splashScreen():
    macropad.display_image("mace.bmp")
    time.sleep(1)
def getNumberOfPlayers():
    while not macropad.encoder_switch:
        players = macropad.encoder + 2
        if players < 2:
            players = 2
        if players > 12:
            players = 12
        OLED[0].text = "Players? {}".format(players)
        OLED.show()
    else:
        # numberOfPlayers = macropad.encoder + 2
        time.sleep(0.4)  # crappy debouce
        return players
macropad = MacroPad()
# Initialze the display
splashScreen()
OLED = macropad.display_text("Chess Clock")
macropad.pixels.fill((0, 0, 0))
numberOfPlayers = getNumberOfPlayers()
while True:
    showAllPlayers()
    # get first player
    firstPlayer = 1
        firstPlayer = macropad.encoder + 2 - numberOfPlayers + 1
        if firstPlayer < 1:
            firstPlayer = 1
        if firstPlayer > numberOfPlayers:
            firstPlayer = numberOfPlayers
        OLED[1].text = "First player? {}".format(firstPlayer)
        OLED.show()
    else:
    OLED[0].text = "Press encoder"
    OLED[1].text = "to begin!"
        continue
    else:
        clearDisplay(OLED)
        time.sleep(0.2)
    # Artificially low 10-second game for testing
    countdown = [10] * numberOfPlayers
    currentPlayer = firstPlayer - 1  # switch to zero-relative
    for key in range(numberOfPlayers):
        macropad.pixels[key] = (0, 0, 0)
        time.sleep(0.2)
    startTime = lightNextPlayer()
    timeRemaining = countdown[currentPlayer]
    while timeRemaining > 0:
        minutes = timeRemaining // 60
        seconds = timeRemaining % 60
        if timeRemaining < 0:
            break
        OLED[0].text = "Player {} {}:{:02d}".format(currentPlayer + 1, minutes, seconds)
        key_event = macropad.keys.events.get()
        if key_event and key_event.pressed:
            if key_event.key_number == currentPlayer:
                macropad.pixels[currentPlayer] = 0x000000
                countdown[currentPlayer] = timeRemaining
                currentPlayer = (currentPlayer + 1) % numberOfPlayers
        time.sleep(0.2) # crappy debouce
        timeRemaining = countdown[currentPlayer] - (time.time() - startTime)
    else:
        OLED[1].text = "Time's up!"
        macropad.pixels.fill(colorLib.INDIGO)
        macropad.pixels[currentPlayer] = colorLib.RED
        time.sleep(5) # Let the agony of defeat soak in a bit.
        clearDisplay(OLED)
        macropad.pixels.fill(0x000000)
johnpark
Re: MACROPAD 2+ Player "Chess" clock
Post by johnpark »
Nicely done, this is a great project!
Return to “AdaBox! Show us what you made!”
