MACROPAD app names?
- Hethacker
MACROPAD app names?
how do you find the application name to use in the MacroPad? for instance, Illustrator for windows is called 'win illustrator', where would I find the names for other applications like Fusion 360 or google chrome? I am using a windows computer.
- plitog
Re: MACROPAD app names?
Are you trying to use the Macropad to start up a new instance of the application? If so, you could look at the name of the .exe in Task Manager after you've started the app.
- Hethacker
okay, I looked at that, and I pulled up Windows Edge internet application. The example application works fine on my computer, but when I compare the code to the .exe they are not the same. The code has Edge written as 'Windows Edge' but the .exe is stated as msedge.exe. I pulled up the .exe by first pulling up task manager and then looking into the application details.
- adafruit_support_carter
Are you asking this in the context of using the MacroPad as shown in this guide?
https://learn.adafruit.com/macropad-hotkeys
