just received my adabox16 essentials today with matrix portal m4 and 64x32 RGB panel.
i connect the matrix portal to the panel as described. i connect the red/black power/bnd wires to the matrix portal as described and plug in to the vcc/gnd connector at the back of the panel.
When powering up using USB C 30W charger from my macbook, nothing happens. No leds on the matrix portal fire up, nothing on the panel lids up. when I unplug the power cable from the panel and then connect the USB C power, the leds on the matrix portal fire up.
I am also able to connect, load python scripts and run them on the matrix portal fine when connecting to my macbook. And I can monitor through my terminal using screen.
So one reason or another the matrix portal and panel don't seem to be working together.
Any ideas / help is welcome...
ADABOX16 - Matrix portal won't fire when panel connected
- dupolas
- dupolas
Re: ADABOX16 - Matrix portal won't fire when panel connected
update: when using a phone charger with usb c cable the panel and matrix portal do work. so maybe the Apple charger is messing up.
- Franklin97355
Thanks for the update. It will help others with similar problems.
