The diagram of the pinouts for the I2C connector on the MacroPad is wrong!
https://learn.adafruit.com/assets/103286
The pinout order is the same as the FunHouse, from the top SCL/SDA/3.3V/GND.
ADABOX019 MacroPad I2C diagram has wrong pinout.
- SpaceCoaster
- adafruit2
Re: ADABOX019 MacroPad I2C diagram has wrong pinout.
you can use the wire colors to identify pins
- SpaceCoaster
Thanks, I was making some cables and I used the MacroPad pin out diagram as my model. It is wrong!
I reported it as a bug.
- kattni
Apologies for the inconvenience. I replied on GitHub. The issue was with the Fritzing object which is used for the basis of the PrettyPins images. I have updated both.
- SpaceCoaster
No inconvenience at all. Your documentation is wonderful and very much appreciated! My apologies for spamming it to several places.
