External Interrupts
External Interrupts
by NerdFighter on Fri Jan 12, 2018 6:52 pm
Hi! I'm working on a project with a Trinket M0 and a vibration sensor as input. I would like to configure one of the IO pins as an interrupt line to make sure I detect the vibration sensor's very brief state changes regardless of when the occur during my program loop. Are there any existing CircuitPython libraries for simple interrupts on the Trinket M0?
NerdFighter
Re: External Interrupts
by adafruit_support_carter on Fri Jan 12, 2018 7:06 pm
Sorry, no. CircuitPython does not (currently) support interrupts. The current focus is on making it a good experience for beginners that have never programmed.
by tannewt2 on Sat Jan 13, 2018 1:47 pm
NerdFighter, You could use pulsio.PulseIn to track if pulses have happened. It has a circular buffer so you won't likely miss the event and uses interrupts internally. Make sure you have 2.2.0 installed. It wasn't available for trinket until 2.1.0.
tannewt2
cron
