I've installed micropython on a nodemcu and have been playing around. Whenever I reset the board, or power down, i lose the network and webrepl settings. I've created a boot.py file and uploaded it using webrepl, but still lose everything upon power cycle. I tried installing ampy to verify if the boot.py file is in fact in the correct spot. However, when I try to run even ampy --help I get the following error...
lkdfldk@MacBook-Air:~/Downloads$ ampy --help
File "/usr/local/bin/ampy", line 11, in <module>
load_entry_point('adafruit-ampy==1.0.3', 'console_scripts', 'ampy')()
File "/Library/Python/2.7/site-packages/pkg_resources/__init__.py", line 567, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/Library/Python/2.7/site-packages/pkg_resources/__init__.py", line 2604, in load_entry_point
return ep.load()
File "/Library/Python/2.7/site-packages/pkg_resources/__init__.py", line 2264, in load
return self.resolve()
File "/Library/Python/2.7/site-packages/pkg_resources/__init__.py", line 2270, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "/Library/Python/2.7/site-packages/ampy/cli.py", line 30, in <module>
import ampy.files as files
ImportError: No module named files
Anybody see this error and can offer guidance in a solution?
-John
ampy error
- jmleczko
Re: ampy error
Never mind, I figured it out.
I was trying to define a function within boot.py (following an example). I just eliminated the function and executed straight commands and now my network and webrepl get set up on boot.
