New to this
Re: New to this
by giga on Fri Apr 13, 2018 4:11 pm
Here's what I have with me really fumbling around - I now have white with some blue but can't get it to blink and can't even get fade at all
from digitalio import DigitalInOut, Direction
import board
import neopixel
import time
pixpin = board.D1
numpix = 10
led = DigitalInOut(board.D13)
led.direction = Direction.OUTPUT
strip = neopixel.NeoPixel(pixpin, numpix, bpp=4, brightness=.5, auto_write=True)
color1 = (0, 0, 0, 255)
color2 = (0, 0, 255, 255)
while True:
   strip[1] = color1
   strip[2] = color1
   strip[3] = color1
   strip[4] = color1
   strip[5] = color1
   strip[6] = color1
   strip[7] = color1
    time.sleep(.1)
   strip[1] = color2
   strip[2] = color2
   strip[3] = color2
   strip[4] = color2
   strip[5] = color2
   strip[6] = color2
   strip[7] = color2
    time.sleep(.1)
giga
Re: New to this
by adafruit_support_carter on Fri Apr 13, 2018 4:55 pm
Here's another useful link. This guide just went up a little while ago:
https://learn.adafruit.com/circuitpytho ... n-neopixel
There is a fill function you can use if you just want to set all pixels to the same color. Also, to clear or turn off the pixels, just set the color to black, or all zeros. So you can do something like this:
   strip[1] = color1
   strip[2] = color1
   strip[3] = color1
   strip[4] = color1
   strip[5] = color1
   strip[6] = color1
   strip[7] = color1
with this:
   strip.fill(color1)
Blink would be something like:
while True:
    strip.fill(color1)
    time.sleep(0.1)
    strip.fill((0,0,0,0))
    time.sleep(0.1)
Re: New to this
by giga on Fri Apr 13, 2018 11:25 pm
When I do this I'm getting a syntax error on the first time.sleep(0.1), says python can't understand?
while True:
    strip.fill(color1)
    time.sleep(0.1)
    time.sleep(0.1)
giga
Re: New to this
by giga on Fri Apr 13, 2018 11:53 pm
giga wrote:When I do this I'm getting a syntax error on the first time.sleep(0.1), says python can't understand?
while True:
    strip.fill(color1)
    time.sleep(0.1)
    time.sleep(0.1)
Ok 4 whatever reason I rewrote it and it worked. Not just the fade to on part. Yikes! Lol
giga
Re: New to this
by giga on Sat Apr 14, 2018 12:22 am
so I'm finally happy with the first part of this - I may tinker a bit more with the timing and colors but I need to figure out the fade from 0 to on and stay on thing now. Basically it's simulating a machine coming awake kind of thing.
No idea if there's a cleaner way of doing this but it works lol
import board
import neopixel
import time
pixpin = board.D1
numpix = 10
strip = neopixel.NeoPixel(pixpin, numpix, bpp=4, brightness=.4, auto_write=True)
color1 = (100, 0, 0, 50)
color2 = (180, 0, 0, 20)
color3 = (255, 0, 0, 0)
while True:
    strip.fill(color1)
    time.sleep(.002)
    strip.fill((0, 0, 0, 0))
    time.sleep(.03)
    strip.fill(color2)
    time.sleep(.07)
    time.sleep(.1)
    strip.fill(color3)
    time.sleep(.3)
    time.sleep(.5)
giga
Re: New to this
by adafruit_support_carter on Mon Apr 16, 2018 10:52 am
Looks like you're figuring it out. Try something, if you get some error message, try and work through that. Change a few more things, keep slowly changing the code to get where you want. Learn stuff along the way. So just keep playing with the code and look at other example for ideas, etc.
Re: New to this
by giga on Mon Apr 16, 2018 8:04 pm
I was messing with this for a few hours till I just gave up :(
import board
import neopixel
import time
#import pulseio
pixpin = board.D0
numpix = 32
#Brightness = 0
#fade_amount = 1285
#counter = 0
strip = neopixel.NeoPixel(pixpin, numpix, bpp=4, brightness=.03, auto_write=True,)
color1 = (100, 0, 0, 90)
color2 = (200, 0, 0, 30)
color4 = (0, 0, 255, 0)
while True:
    strip.fill(color1)
    time.sleep(0)
    time.sleep(.04)
    strip.fill(color2)
    time.sleep(.08)
    time.sleep(.2)
    strip.fill(color3)
    time.sleep(.2)
    time.sleep(.02)
#    if (brightness <= 0):
#        fade_amount = -fade_amount
#        counter += 1
#    elif (brightness >= 65635):
#        counter += 1
giga
Re: New to this
by adafruit_support_carter on Mon Apr 16, 2018 11:17 pm
time.sleep() is in units of seconds. The values you are using are pretty small. color3 stays on the longest at 0.2 seconds, but even that is pretty quick.
Re: New to this
by giga on Tue Apr 17, 2018 8:05 am
Yeah I'm ok with that and I know it's in milliseconds, I want it to blink very fast as it boots up, then fade to on and stay on.
giga
Re: New to this
by giga on Tue Apr 17, 2018 1:14 pm
latest messing around to no avail
import board
import neopixel
import time
import pulseio
pixpin = board.D0
numpix = 32
# strip = pulseio.PWMOut(board.D0)
# FADE_SLEEP = 10
# def duty_cycle(percent):
#    return int(percent / 100.0 * 65535.0)
strip = neopixel.NeoPixel(pixpin, numpix, bpp=4, brightness=.02, auto_write=False,)
while True:
    strip.fill(color1)
    strip.show()
    time.sleep(.001)
    strip.show()
    time.sleep(.01)
    strip.fill(color2)
    strip.show()
    time.sleep(.1)
    strip.show()
    time.sleep(.1)
    strip.fill(color3)
    strip.show()
    time.sleep(.1)
    strip.show()
    time.sleep(.2)
#    for i in range(100):
#        strip.duty_cycle = duty_cycle(i)
#        time.sleep(FADE_SLEEP)
giga
