Run CircuitPython on custom SAMD21
by binux on Wed Jun 13, 2018 8:50 am
Hello everyone,
I have a custom SAMD21G18A board. I program it normally with my J-Link, but I would like to test CircuitPython on it.
My question is how can I get this running on it?
Which release should I use (of which adafruit derivate) and is there a way flashing the firmware via J-Link?
Thanks already in advance.
binux
Re: Run CircuitPython on custom SAMD21
by danhalbert on Wed Jun 13, 2018 9:41 am
There are a number of people who have done this already. Many hang out on the #circuitpython channel on discord: https://adafru.it/discord.
CircuitPython is available at https://github.com/adafruit/circuitpython. Build instructions are here: https://learn.adafruit.com/building-circuitpython
You can make up a custom board definition based on the pins you've exposed, any SPI flash on the board, etc. Look in circuitpython/ports/atmel-samd/boards/.
Most boards are set up to load CircuitPython at 8k above 0x0 in the address space, above the UF2 bootloader: https://github.com/adafruit/uf2-samdx1.
danhalbert
