NRF52840 Corrupt file system
by cartere on Mon Jan 07, 2019 6:24 pm
https://github.com/adafruit/circuitpyth ... lpha.5.bin
made the mistake of installing this file to FTHRBOOT instead of the UF2 now file system is hosed. Is there a way to clear it?
cartere
Re: NRF52840 Corrupt file system
by GaryGJohnson on Mon Jan 07, 2019 9:08 pm
There's some instructions here for when the file system gets clobbered: https://learn.adafruit.com/welcome-to-c ... sues-19-20
Also, if you're looking for UF2 builds, they started building them in the nightlies but they're not linked on the Github page yet. You can grab the latest here: https://adafruit-circuit-python.s3.amaz ... 0_express/
I just put a build on mine and was able to get it up and running.
GaryGJohnson
by tannewt2 on Mon Jan 07, 2019 9:52 pm
The BOOT filesystem is fake so a simple restart into the bootloader should clear it. Are you still having an issue?
tannewt2
by cartere on Mon Jan 07, 2019 11:15 pm
When I try to drop the Circuitpython UF2 on BOOT it complains the file is to large.
cartere
by tannewt2 on Wed Jan 09, 2019 9:37 pm
What version of the bootloader is it? It should be in a file on the drive.
tannewt2
by cartere on Thu Jan 10, 2019 8:57 am
UF2 Bootloader 0.2.6 lib/nrfx (v1.1.0-1-g096e770) lib/tinyusb (legacy-525-ga1c59649) s140 6.1.1
Model: Adafruit Feather nRF52840 Express
Board-ID: NRF52-Bluefruit-v0
Bootloader: s140 6.1.1
Date: Dec 21 2018
The other concern is I do not see a serial port after a regular reset.
cartere
by tannewt2 on Thu Jan 10, 2019 1:46 pm
That is the latest bootloader.
What does the NeoPixel do after a regular reset?
I'm running out of ideas for this.
tannewt2
by cartere on Fri Jan 11, 2019 9:50 am
Neopixel flashes red, Win10 USB chimes followed by Windows does not recognize this device. All this occurred within 15 minutes of plugging it in for the first time.
cartere
by tannewt2 on Fri Jan 11, 2019 2:02 pm
If the bootloader is reliable it doesn't seem like a hardware issue.
You should get a yellow flash if circuitpython is working ok. The red L led should blink as well.
Are you on Discord (https://adafru.it/discord)? I can try and send you test builds of CircuitPython there.
tannewt2
by cartere on Fri Jan 11, 2019 3:16 pm
yest as cartere
cartere
