📬❄️📦Adafruit Holiday Shipping Deadlines 2019: Attention all domestic customers! Please place UPS Ground and USPS First Class & Priority orders by 11am ET Monday December 9, 2019 📬❄️📦 Attention all international customers! Please place all UPS WORLDWIDE EXPRESS; SAVER, and DHL EXPRESS WORLDWIDE orders by 11am ET Monday December 9, 2019 📬❄️📦
Is using circuitpython on rPi the only way to use a debugger
by geekguy on Wed Aug 14, 2019 2:42 am
I am at a point where I would really like to be able to get "inside" a circuitpython script while it is running. I would like to be able to set breakpoints and examine and change at variables inside the running script., then continue. Print statements are just not giving me the information I need.
I expect there is no way to do this on a microcontroller, but would it work if I were running circuitpython on a Raspberry Pi?
8-Dale
geekguy
Re: Is using circuitpython on rPi the only way to use a debu
by jerryn on Wed Aug 14, 2019 2:54 am
You can use a J-Link with gdb to debug an Atmel (SAMD21/51) or Nordic (nRF52840) running circuitpython. https://learn.adafruit.com/debugging-the-samd21-with-gdb
While you can run the python scripts on a Raspberry Pi, you are not actually running CircuitPython, so your results may not be as meaningful.
jerryn
by geekguy on Wed Aug 14, 2019 3:18 am
jerryn wrote:You can use a J-Link with gdb to debug an Atmel (SAMD21/51) or Nordic (nRF52840) running circuitpython. https://learn.adafruit.com/debugging-the-samd21-with-gdb
Is all this complexity really necessary if all I want to do is set source breakpoints, examine/change variables, and step through code at the source level?
jerryn wrote:While you can run the python scripts on a Raspberry Pi, you are not actually running CircuitPython, so your results may not be as meaningful.
How would the results of doing this not be meaningful?
8-Dale
geekguy
by jerryn on Wed Aug 14, 2019 3:42 am
The python script executes code from the circuitpython core. The “core” is not actually running on the Raspberry Pi so your source code is not the same as on a micro controller. It all depends on what you are debugging.
I’m certainly not telling you there is only one way to approach it. I was just pointing out that you can indeed run a debugger on the micro controller.
Perhaps I am not understanding what you want to do.
Hopefully someone else can help. Good luck.
jerryn
by jerryn on Wed Aug 14, 2019 3:50 am
On review of your initial post, I do think I misunderstood your request. I was thinking of much lower level debugging. Sorry for my confusion.
jerryn
by jerryn on Wed Aug 14, 2019 6:38 am
FYI - there was discussion of something relevant awhile ago - I don't know if there is active development at tis time. See this issue discussion: https://github.com/adafruit/circuitpython/issues/298
jerryn
by geekguy on Wed Aug 14, 2019 12:08 pm
jerryn wrote:FYI - there was discussion of something relevant awhile ago - I don't know if there is active development at tis time. See this issue discussion: https://github.com/adafruit/circuitpython/issues/298
Thank you for this pointer! I read the discussion and added my quarter's worth. :)
8-Dale
geekguy
