Circuitpython: make ../ports/unix
by oriesta on Thu Sep 12, 2019 8:06 am
I'm having trouble building the project located in circuitplayground/ports/unix. Make output is:
(circuitpython) oriesta@LINK:~/Projects/circuitpython/ports/unix$ make V=1
GEN build/genhdr/mpversion.h
GEN build/genhdr/moduledefs.h
GEN build/genhdr/qstr.i.last
In file included from ../../lib/axtls/ssl/ssl.h:75,
from ../../extmod/modussl_axtls.c:37:
../../lib/axtls/ssl/tls1.h:43:10: fatal error: version.h: No such file or directory
#include "version.h"
compilation terminated.
I am able to build micropython/ports/unix project just fine so I diffed the two projects and noticed some changes in some of the parent *.mk files that could be the problem but I have yet to dig deep enough.
Just curious if others are able to build the unix port of circuitpython. I am running this in a kubuntu 19.04 VM on a WIN10 host. and have setup my build environment per the instructions found at learn.adafruit.com/building-circuitpython/build-circuitpython.
oriesta
Re: Circuitpython: make ../ports/unix
by tannewt2 on Thu Sep 12, 2019 4:06 pm
We use the UNIX ports in our CI so it should work just fine. Did you `make -C ports/unix deplibs -j2` before doing the regular make?
Here is how the CI does it: https://github.com/adafruit/circuitpyth ... ld.yml#L37
tannewt2
by oriesta on Fri Sep 13, 2019 7:31 pm
I missed the dependency build step and when I try I get an error re: a missing autoreconf file in the libffi folder. I'll start running that down next. Thanks so much for suggestion.
oriesta
