DHT11 Sensor with adafruit_dht error
by ameeruak on Fri Nov 08, 2019 7:55 am
I am using the DHT 11 sensor on raspberry pi but when I set the board.D4 the error it gives is
Unable to set Line 4 to input
What is the possible cause for this?
ameeruak
Re: DHT11 Sensor with adafruit_dht error
by jerryn on Fri Nov 08, 2019 11:06 am
I just ran this example without any problem:
import time
import board
import adafruit_dht
# Initial the dht device, with data pin connected to:
dhtDevice = adafruit_dht.DHT11(board.D4)
while True:
    try:
        # Print the values to the serial port
        temperature_c = dhtDevice.temperature
        temperature_f = temperature_c * (9 / 5) + 32
        humidity = dhtDevice.humidity
        print("Temp: {:.1f} F / {:.1f} C    Humidity: {}% "
              .format(temperature_f, temperature_c, humidity))
    except RuntimeError as error:
        # Errors happen fairly often, DHT's are hard to read, just keep going
        print(error.args[0])
    time.sleep(2.0)
Did you install “Blinka” following this guide ? https://learn.adafruit.com/circuitpython-on-raspberrypi-linux
jerryn
by ameeruak on Fri Nov 08, 2019 4:09 pm
Actually it runs once but when I run it on the same pin again it dosent work, something like it maybe does not GPIO.cleanup() the pins. I tried doing the cleanup in the code but I guess the pin still stays occupied and dosent work for some reason.
Are you facing the same problem if you rerun the code on the same pin?
ameeruak
by jerryn on Fri Nov 08, 2019 4:55 pm
No. It works repeatedly for me.
jerryn
by jerryn on Fri Nov 08, 2019 4:58 pm
However -- I do get that error if I try to run two instances of the code at the same time!
I usually terminate the running program with a Control-C
Do you possibly have a old copy still running?
jerryn
