So, here's one of my attempts...
- Code: Select all | TOGGLE FULL SIZE
import time
import board
import microcontroller
import displayio
import busio
from digitalio import DigitalInOut
from analogio import AnalogIn
import neopixel
import adafruit_adt7410
from adafruit_bitmap_font import bitmap_font
from adafruit_display_text.label import Label
from adafruit_button import Button
import adafruit_touchscreen
from adafruit_pyportal import PyPortal
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_lidarlite
# ------------- Inputs and Outputs Setup ------------- #
try: # attempt to init. the temperature sensor
i2c_bus = busio.I2C(board.SCL, board.SDA)
except ValueError:
# Did not find ADT7410. Probably running on Titano or Pynt
sensor = None
# init. the light sensor
sensor = adafruit_lidarlite.LIDARLite(i2c_bus)
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=1)
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
# ---------- Sound Effects ------------- #
soundDemo = '/sounds/sound.wav'
soundBeep = '/sounds/beep.wav'
soundTab = '/sounds/tab.wav'
# ------------- Other Helper Functions------------- #
# Helper for cycling through a number set of 1 to x.
def numberUP(num, max_val):
num += 1
if num <= max_val:
return num
else:
return 1
# ------------- Screen Setup ------------- #
pyportal = PyPortal()
display = board.DISPLAY
display.rotation = 0
# Backlight function
# Value between 0 and 1 where 0 is OFF, 0.5 is 50% and 1 is 100% brightness.
def set_backlight(val):
val = max(0, min(1.0, val))
board.DISPLAY.auto_brightness = False
board.DISPLAY.brightness = val
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# ------Rotate 0:
screen_width = 320
screen_height = 240
ts = adafruit_touchscreen.Touchscreen(board.TOUCH_XL, board.TOUCH_XR,
board.TOUCH_YU, board.TOUCH_YD,
calibration=((5200, 59000),
(5800, 57000)),
size=(screen_width, screen_height))
# ------------- Display Groups ------------- #
splash = displayio.Group(max_size=15) # The Main Display Group
view1 = displayio.Group(max_size=15) # Group for View 1 objects
view2 = displayio.Group(max_size=15) # Group for View 2 objects
view3 = displayio.Group(max_size=15) # Group for View 3 objects
def hideLayer(hide_target):
try:
splash.remove(hide_target)
except ValueError:
pass
def showLayer(show_target):
try:
time.sleep(0.1)
splash.append(show_target)
except ValueError:
pass
# ------------- Setup for Images ------------- #
# Display an image until the loop starts
pyportal.set_background('/images/loading.bmp')
bg_group = displayio.Group(max_size=1)
splash.append(bg_group)
icon_group = displayio.Group(max_size=1)
icon_group.x = 180
icon_group.y = 120
icon_group.scale = 1
view2.append(icon_group)
# This will handel switching Images and Icons
def set_image(group, filename):
"""Set the image file for a given goup for display.
This is most useful for Icons or image slideshows.
:param group: The chosen group
:param filename: The filename of the chosen image
print("Set image to ", filename)
if group:
group.pop()
if not filename:
return # we're done, no icon desired
image_file = open(filename, "rb")
image = displayio.OnDiskBitmap(image_file)
try:
image_sprite = displayio.TileGrid(image, pixel_shader=displayio.ColorConverter())
except TypeError:
image_sprite = displayio.TileGrid(image, pixel_shader=displayio.ColorConverter(),
position=(0, 0))
group.append(image_sprite)
set_image(bg_group, "/images/BGimage.bmp")
# ---------- Text Boxes ------------- #
# Set the font and preload letters
font = bitmap_font.load_font("/fonts/Helvetica-Bold-16.bdf")
font.load_glyphs(b'abcdefghjiklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890- ()')
# Default Label styling:
TABS_X = 20
TABS_Y = 50
# Text Label Objects
feed1_label = Label(font, text="Text Wondow 1", color=0xE39300, max_glyphs=200)
feed1_label.x = TABS_X+25
feed1_label.y = TABS_Y
view1.append(feed1_label)
feed2_label = Label(font, text="Text Wondow 2", color=0xFFFFFF, max_glyphs=200)
feed2_label.x = TABS_X
feed2_label.y = TABS_Y
view2.append(feed2_label)
sensors_label = Label(font, text="Data View", color=0x03AD31, max_glyphs=200)
sensors_label.x = TABS_X
sensors_label.y = TABS_Y
view3.append(sensors_label)
sensor_data = Label(font, text="Data View", color=0x03AD31, max_glyphs=100)
sensor_data.x = TABS_X+150
sensor_data.y = 120
# view3.append(sensor_data)
text_hight = Label(font, text="M", color=0x03AD31, max_glyphs=10)
# return a reformatted string with word wrapping using PyPortal.wrap_nicely
def text_box(target, top, string, max_chars):
text = pyportal.wrap_nicely(string, max_chars)
new_text = ""
test = ""
for w in text:
new_text += '\n'+w
test += 'M\n'
text_hight.text = test # Odd things happen without this
glyph_box = text_hight.bounding_box
target.text = "" # Odd things happen without this
target.y = int(glyph_box[3]/2)+top
target.text = new_text
# ---------- Display Buttons ------------- #
# Default button styling:
BUTTON_HEIGHT = 20
BUTTON_WIDTH = 80
# We want three buttons across the top of the screen
TAPS_HEIGHT = 30
TAPS_WIDTH = int(screen_width/3)
TAPS_Y = 0
# We want two big buttons at the bottom of the screen
BIG_BUTTON_HEIGHT = int(screen_height/5.2)
BIG_BUTTON_WIDTH = int(screen_width/2)
BIG_BUTTON_Y = int(screen_height-BIG_BUTTON_HEIGHT)
# This group will make it easy for us to read a button press later.
buttons = []
# Main User Interface Buttons
button_view1 = Button(x=0, y=0,
width=TAPS_WIDTH, height=TAPS_HEIGHT,
label="Distance", label_font=font, label_color=0xff7e00,
fill_color=0x5c5b5c, outline_color=0x767676,
selected_fill=0x1a1a1a, selected_outline=0x2e2e2e,
selected_label=0x525252)
buttons.append(button_view1) # adding this button to the buttons group
button_view2 = Button(x=TAPS_WIDTH, y=0,
label="IR Camera", label_font=font, label_color=0xff7e00,
#buttons.append(button_view2) # adding this button to the buttons group
button_view3 = Button(x=TAPS_WIDTH*2, y=0,
label="Gas Sensor", label_font=font, label_color=0xff7e00,
buttons.append(button_view3) # adding this button to the buttons group
button_switch = Button(x=0, y=BIG_BUTTON_Y,
width=BIG_BUTTON_WIDTH, height=BIG_BUTTON_HEIGHT,
label="Switch", label_font=font, label_color=0xff7e00,
# buttons.append(button_switch) # adding this button to the buttons group
button_2 = Button(x=BIG_BUTTON_WIDTH, y=BIG_BUTTON_Y,
label="Light ON/OFF", label_font=font, label_color=0xff7e00,
# buttons.append(button_2) # adding this button to the buttons group
# Add all of the main buttons to the splash Group
for b in buttons:
splash.append(b.group)
# Make a button to change the icon image on view2
button_icon = Button(x=150, y=60,
width=BUTTON_WIDTH, height=BUTTON_HEIGHT,
label="Icon", label_font=font, label_color=0xffffff,
fill_color=0x8900ff, outline_color=0xbc55fd,
selected_fill=0x5a5a5a, selected_outline=0xff6600,
selected_label=0x525252, style=Button.ROUNDRECT)
# buttons.append(button_icon) # adding this button to the buttons group
#pylint: disable=global-statement
def switch_view(what_view):
global view_live
if what_view == 1:
hideLayer(view2)
hideLayer(view3)
button_view1.selected = True
button_view2.selected = False
button_view3.selected = False
showLayer(view1)
view_live = 1
print("View1 On")
elif what_view == 2:
# global icon
hideLayer(view1)
hideLayer(view3)
button_view1.selected = False
button_view2.selected = True
button_view3.selected = True
showLayer(view2)
view_live = 2
print("View2 On")
else:
hideLayer(view1)
hideLayer(view2)
showLayer(view3)
view_live = 3
print("View3 On")
#pylint: enable=global-statement
# Set veriables and startup states
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
button_switch.label = "OFF"
button_switch.selected = True
# Update out Labels with display text.
text_box(feed1_label, TABS_Y,
"Gas Readings ### x ###.", 30)
'Gas Readings from AdafruitIO'
.format(feed1_label.bounding_box[2], feed1_label.bounding_box[3]*2), 30)
text_box(feed2_label, TABS_Y, 'Garmin Distance Sensor', 18)
text_box(sensors_label, TABS_Y,
"SENSOR DATA", 28)
board.DISPLAY.show(splash)
# ------------- Code Loop ------------- #
while True:
try:
# We print tuples so you can plot with Mu Plotter
print((sensor.distance,))
except RuntimeError as e:
# If we get a reading error, just print it and keep truckin'
print(e)
time.sleep(0.01) # you can remove this for ultra-fast measurements!
# ------------- Handle Button Press Detection ------------- #
if touch: # Only do this if the screen is touched
# loop with buttons using enumerate() to number each button group as i
for i, b in enumerate(buttons):
if b.contains(touch): # Test each button to see if it was pressed
print('button%d pressed' % i)
if i == 0 and view_live != 1: # only if view1 is visable
pyportal.play_file(soundTab)
switch_view(1)
while ts.touch_point:
pass
if i == 1 and view_live != 2: # only if view2 is visable
switch_view(2)
pass
if i == 2 and view_live != 3: # only if view3 is visable
switch_view(3)
pass
if i == 3:
pyportal.play_file(soundBeep)
# Toggle switch button type
if switch_state == 0:
switch_state = 1
b.label = "COLOR"
b.selected = False
pixel.fill(WHITE)
print("Swich ON")
else:
switch_state = 0
b.label = "OFF"
b.selected = True
pixel.fill(BLACK)
print("Swich OFF")
# for debounce
pass
print("Swich Pressed")
if i == 4:
# Momentary button type
b.selected = True
print('Button Pressed')
button_mode = numberUP(button_mode, 5)
if button_mode == 1:
pixel.fill(RED)
elif button_mode == 2:
pixel.fill(YELLOW)
elif button_mode == 3:
pixel.fill(GREEN)
elif button_mode == 4:
pixel.fill(BLUE)
elif button_mode == 5:
pixel.fill(PURPLE)
switch_state = 1
button_switch.label = "COLOR"
button_switch.selected = False
# for debounce
pass
print("Button released")
b.selected = False
if i == 5 and view_live == 2: # only if view2 is visable
b.selected = True
pass
print("Icon Button Pressed")
icon = numberUP(icon, 3)
if icon == 1:
icon_name = "Ruby"
elif icon == 2:
icon_name = "Gus"
elif icon == 3:
icon_name = "Billie"
b.selected = False
"Image".format(icon_name), 18)
set_image(icon_group, "/images/"+icon_name+".bmp")
if i == 6 and view_live == 3: # only if view3 is visable
b.selected = True
pass
print("Sound Button Pressed")
pyportal.play_file(soundDemo)
b.selected = False
And I get this in the REPL:
File "code.py", line 29, in <module>
File "adafruit_lidarlite.py", line 94, in __init__
File "adafruit_bus_device/i2c_device.py", line 50, in __init__
File "adafruit_bus_device/i2c_device.py", line 166, in __probe_for_device
File "adafruit_bus_device/i2c_device.py", line 163, in __probe_for_device
ValueError: No I2C device at address: 0x62
This is all Greek to me... and I failed Greek in college.
Someone, please help!
