Here is a full printout of the error message in the terminal window:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 154, in __probe_for_device
self.i2c.writeto(self.device_address, b"")
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 121, in writeto
return self._i2c.writeto(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 49, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 308, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 160, in __probe_for_device
self.i2c.readfrom_into(self.device_address, result)
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 111, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 56, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end - start)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 179, in read_bytes
return self._device.read(number)
File "rfm9x_check.py", line 36, in <module>
display = adafruit_ssd1306.SSD1306_I2C(128, 32, i2c, reset=reset_pin)
File "/usr/local/lib/python3.7/dist-packages/adafruit_ssd1306.py", line 220, in __init__
self.i2c_device = i2c_device.I2CDevice(i2c, addr)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 50, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 163, in __probe_for_device
raise ValueError("No I2C device at address: 0x%x" % self.device_address)
ValueError: No I2C device at address: 0x3c
