Circuitpython libraries for Ultimate gps logger shield
by muttstang on Sun Jul 25, 2021 8:22 pm
Are there circuitpython libraries to support the ultimate gps logger shield? I have one of the shields and an ESP32-S2 that I'm looking to integrate into a trolling motor controller for my boat. I'm new to circuitpython but have been using arduino for a while (I'm far from an expert) I was thinking it would be better to run circuitpython on this ESP board instead of arduino but need to learn quite a bit about coding in there.
muttstang
Re: Circuitpython libraries for Ultimate gps logger shield
by adafruit_support_carter on Mon Jul 26, 2021 2:38 pm
The shield is just the Ultimate GPS in a different form factor. So you can use the same general GPS library:
https://github.com/adafruit/Adafruit_CircuitPython_GPS
shown here being used with the breakout:
https://learn.adafruit.com/adafruit-ult ... on-parsing
Use the shield guide to get information about the shield's TX/RX pins:
https://learn.adafruit.com/adafruit-ult ... d/overview
Once you're talking over UART, it's all the same - breakout or shield.
by muttstang on Mon Jul 26, 2021 3:04 pm
Sounds good, thanks! I just upgraded the memory in my laptop so I should be good to go to start programming :)
muttstang
