Incorrect I2C pull-up detection on QT Py RP2040
by joeblubaugh on Thu Jul 29, 2021 3:12 am
Twice in the last two days I've been using my QT Py RP2040 with the Stemma QT connector to talk to two devices. I'm initializing the i2c bus using the correct pins, but I get this strange error:
>>> import board
>>> import busio
>>> i2c = busio.I2C(board.SCL1, board.SDA1)
  File "<stdin>", line 1, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
I've tried using the flash_nuke.uf2, reinstalling CircuitPython after nuking, rebooting the board, Safely ejecting the board, removing power, and then rebooting the board ...
joeblubaugh
Re: Incorrect I2C pull-up detection on QT Py RP2040
by dastels on Thu Jul 29, 2021 12:05 pm
What I2C devices do you have connected to the STEMMA-QT connector?
dastels
by joeblubaugh on Fri Jul 30, 2021 12:45 am
I have an APDS-9960, changed to a 0.91" OLED display.
I realized something today - if I plug this into a power adapter and not my MacBook, I don't encounter this issue. The uc starts up quickly and the application seems to work every time.
joeblubaugh
