Broken Guide
Broken Guide
by MattPackwood on Fri May 14, 2021 8:12 pm
it looks like the latest libraries break the Covid Progress Tracker
https://learn.adafruit.com/adafruit-mag ... on-tracker
Matt
MattPackwood
Re: Broken Guide
by dastels on Fri May 14, 2021 10:54 pm
What, exactly, are you seeing?
dastels
Re: Broken Guide
by MattPackwood on Sat May 15, 2021 9:50 am
Sorry, I should have included this....
MattPackwood
Re: Broken Guide
by dastels on Sat May 15, 2021 10:23 am
I'm not seeing a problem looking at the code in the guide. Can you post exactly the code.py that's on the MagTag in case something is different that the code in the guide.
dastels
Re: Broken Guide
by MattPackwood on Sat May 15, 2021 2:14 pm
Here you go...
from adafruit_magtag.magtag import MagTag
from adafruit_progressbar.progressbar import ProgressBar
# Set up where we'll be fetching data from
DATA_SOURCE = "https://raw.githubusercontent.com/owid/covid-19-data/master/public/data/vaccinations/country_data/United%20States.csv"
# Find data for other countries/states here:
# https://github.com/owid/covid-19-data/tree/master/public/data/vaccinations
magtag = MagTag(url=DATA_SOURCE)
magtag.network.connect()
magtag.add_text(
    text_font="/fonts/ncenR14.pcf",
    text_position=((magtag.graphics.display.width // 2) - 1, 8,),
    text_anchor_point=(0.5, 0.5),
    is_data=False,
)  # Title
magtag.add_text(
    text_position=((magtag.graphics.display.width // 2) - 1, 23,),
    is_data=False,
)  # Date
magtag.add_text(
    text_position=((magtag.graphics.display.width // 2) - 1, 40,),
    is_data=False,
)  # Vaccinated text
magtag.add_text(
    text_position=((magtag.graphics.display.width // 2) - 1, 85,),
    is_data=False,
)  # Fully vaccinated text
BAR_WIDTH = magtag.graphics.display.width - 80
BAR_HEIGHT = 25
BAR_X = magtag.graphics.display.width // 2 - BAR_WIDTH // 2
progress_bar = ProgressBar(
    BAR_X, 50, BAR_WIDTH, BAR_HEIGHT, 1.0, bar_color=0x999999, outline_color=0x000000
progress_bar_1 = ProgressBar(
    BAR_X, 95, BAR_WIDTH, BAR_HEIGHT, 1.0, bar_color=0x999999, outline_color=0x000000
magtag.graphics.splash.append(progress_bar)
magtag.graphics.splash.append(progress_bar_1)
magtag.graphics.set_background("/bmps/background.bmp")
try:
    value = magtag.fetch().split("\n")[-2].split(",")
    print("Response is", value)
    vaccinated = int(value[-2]) / 331984513
    fully_vaccinated = int(value[-1]) / 331984513
    magtag.set_text(f"{value[0]} Vaccination Rates", 0, False)
    magtag.set_text(value[1], 1, False)
    magtag.set_text("Vaccinated: {:.2f}%".format(vaccinated * 100), 2, False)
    magtag.set_text(
        "Fully Vaccinated: {:.2f}%".format(fully_vaccinated * 100), 3, False
    progress_bar.progress = vaccinated
    progress_bar_1.progress = fully_vaccinated
    magtag.refresh()
    seconds_to_sleep = 24 * 60 * 60  # Sleep for one day
    print(f"Sleeping for {seconds_to_sleep} seconds")
    magtag.exit_and_deep_sleep(seconds_to_sleep)
except (ValueError, RuntimeError) as e:
    print("Some error occured, retrying! -", e)
MattPackwood
Re: Broken Guide
by MattPackwood on Sat May 15, 2021 2:17 pm
And I did a:
Matt-Packwoods-iMac:~ $ circup update --all
Found device at /Volumes/CIRCUITPY, running CircuitPython 6.2.0.
Downloading latest version information.
  [####################################]  100%
OK
Found 2 module[s] needing update.
Updated neopixel
Updated adafruit_progressbar
And it is working again, so it is a library issue (I guess)
MattPackwood
Re: Broken Guide
by dherrada on Tue Jun 01, 2021 10:49 am
Hi. I'm the author of the guide. Can you try again and see if it's still not working? It could have been fixed in one of the libraries. It also might just need you to copy the libraries over again. Weird stuff like that has happened to me a decent amount, especially on slightly less stable chips like the ESP32-S2
dherrada
Re: Broken Guide
by richjteel on Sun Aug 01, 2021 3:41 pm
I ran into a problem with the covid tracker as well and found that the API used in the guide is no longer updated, as of 7 March 2021, and stopped working in May.
"Notice: The COVID Tracking Project has ended all data collection as of March 7, 2021. The existing API will continue to work until May 2021, but will only include data up to March 7, 2021."
I updated the code to https://covid2019-api.herokuapp.com/v2/total instead. It does not provide the same data but perhaps someone can find a better API to use and add it here. Attached is the updated version of my working code.
MagTag Result
NOTE: I just received the MagTag. I'm working through the MagTag Project Selector project on learn.adafruit.com. I'm attempting to get all of the sub projects listed in the example to work.
covid.py
Updated Code
(3.31 KiB) Downloaded 3 times
richjteel
Re: Broken Guide
by dherrada on Tue Aug 03, 2021 10:21 am
Thanks. That's really helpful. I'll update the guide.
Also, the magtag project selector can be a bit complicated to set up. Feel free to ask me if you're having any issues.
dherrada
Re: Broken Guide
by dherrada on Tue Aug 03, 2021 10:23 am
Oh wait, can you confirm that this is the guide you are talking about? https://learn.adafruit.com/adafruit-mag ... r/overview
dherrada
Re: Broken Guide
by richjteel on Tue Aug 03, 2021 4:20 pm
@dherrada, Sorry, that is not the one that I was commenting on. I did not realize there were two covid apps for the MagTag. I was referring to the other one at https://learn.adafruit.com/magtag-covid ... ot-display. I totally posted in the wrong thread.
I thought that I would be helpful but instead hijacked a thread unintentionally. Would you want me to delete my post and post it as a new topic to see if it will help someone else out or should I leave it here?
richjteel
Re: Broken Guide
by Cutie_And_Grump on Fri Aug 06, 2021 1:51 pm
richjteel wrote:I ran into a problem with the covid tracker as well and found that the API used in the guide is no longer updated, as of 7 March 2021, and stopped working in May.
richjteel I found https://apidocs.covidactnow.org/ to work quite well. You do need to sign up for a free api key to access the data. There is quite a bit of data available to access, country and state levels. I hope this helps.
Cutie_And_Grump
