Help Needed: Text output from the Macropad RP2040
demsecure
Post by demsecure »
I received the Macropad and followed this guide:
https://learn.adafruit.com/macropad-hot ... oject-code
I'm on Windows 10.
I've had to alter several of the bundled macros because multiple windows computers refuse to output any text. eg: instead of [Keycode.CONTROL, Keycode.SHIFT, 't'] opening a previously closed tab, I need to use [Keycode.CONTROL, Keycode.SHIFT, Keycode.T]
I'd like to use the macropad for text insertion/expansion, but without the ability to export text, I'm dead in the water.
even something as simple ['test sentence'] causes the macropad to stop running.
Not sure what I'm doing wrong. I'm including a code sample that appears to be working for others, but not for me:
# MACROPAD Hotkeys example: Multi-Keypress command Example
#from adafruit_hid.keycode import Keycode # REQUIRED if using Keycode.* values
#from adafruit_hid.keyboard import Keyboard # REQUIRED if using Keycode.* values
import usb_hid
kbd = Keyboard(usb_hid.devices)
app = {                    # REQUIRED dict, must be named 'app'
    'name' : 'Example', # Application name
    'macros' : [           # List of button macros...
        # COLOR    LABEL    FLAG(Optional)  KEY SEQUENCE
        # 1st row ----------
        (0x200000, 'Chrome', [999], [Keycode.WINDOWS, 'chrome', Keycode.ENTER]), #ADDED - Note the extra list that contains the 999
        (0x000040, 'Reopen Tab', [Keycode.CONTROL, Keycode.SHIFT, 't']),
        (0x000000, '?', []),
        # 2nd row ---------
        # 3rd row ----------
        # 4th row ----------
        (0x000000, 'test text', ['test sentance']),
        # Encoder button ---
        (0x000000, '', []) #
Any help would be greatly appreciated.
adafruit_support_carter
Re: Help Needed: Text output from the Macropad RP2040
What is the FLAG entry?
When it stops running, does it print out an error?
demsecure
Post by demsecure »
It just desplays "Code done running." on the display.
the second keycap is lit up blue, the first keycap flashes blue sporadically and the 11th key (bottom row middle) lights up white.
demsecure
Post by demsecure »
and...curiously.. my windows computer behaves as if the Ctrl key is being held down after I try to execute the "Reopen Tab" command above. eg: using my scroll wheel on the mouse causes Chrome to change the zoom level, not scroll the page.
That means the code exited. Which it shouldn't, unless it hit an error. If it did hit an error, there would be an associated message above this.
Can you try going back to the original code from the guide so we can rule out it being anything with your modifications.
Post the full line in your macro file where you tried this.
demsecure
Post by demsecure »
Code snippet -
That's what led me to make alterations. any code used that just used a alpha character such as:
(0x000040, 'Private', [Keycode.CONTROL, 'N']),
from the "Windows Edge Default"
causes the error.
hope this helps!
Whats the text of the error message?
demsecure
Post by demsecure »
Windows Edge Code:
# MACROPAD Hotkeys example: Microsoft Edge web browser for Windows
    'name' : 'Windows Edge', # Application name
        # COLOR    LABEL    KEY SEQUENCE
        (0x004000, '< Back', [Keycode.ALT, Keycode.LEFT_ARROW]),
        (0x004000, 'Fwd >', [Keycode.ALT, Keycode.RIGHT_ARROW]),
        (0x400000, 'Up', [Keycode.SHIFT, ' ']),      # Scroll up
        # 2nd row ----------
        (0x202000, '- Size', [Keycode.CONTROL, Keycode.KEYPAD_MINUS]),
        (0x202000, 'Size +', [Keycode.CONTROL, Keycode.KEYPAD_PLUS]),
        (0x400000, 'Down', ' '),                     # Scroll down
        (0x000040, 'Reload', [Keycode.CONTROL, 'r']),
        (0x000040, 'Home', [Keycode.ALT, Keycode.HOME]),
        (0x000000, 'Ada', [Keycode.CONTROL, 'n', -Keycode.COMMAND,
                           'www.adafruit.com\n']),   # Adafruit in new window
        (0x800000, 'Digi', [Keycode.CONTROL, 'n', -Keycode.COMMAND,
                            'www.digikey.com\n']),   # Digi-Key in new window
        (0x101010, 'Hacks', [Keycode.CONTROL, 'n', -Keycode.COMMAND,
                             'www.hackaday.com\n']), # Hack-a-Day in new win
        (0x000000, '', [Keycode.CONTROL, 'w']) # Close tab
Same error. "code done running" on the screen and the computer behaves as if the Ctrl button is held down.
The above code should *not* be your code.py. Your code.py file should contain the main project code from here:
The code you show above looks like a configuration file, which should be placed in the macros subfolder:
https://learn.adafruit.com/macropad-hot ... igurations
This is not an error. That is the normal message you'll see when code is done running. If you are getting that, it seems to indicate you are not running the actual project code. That code has a forever loop and should never exit. Or if it does, it with an actual error message.
demsecure
Post by demsecure »
Yes.. sorry I wasn't clear. Here's my code.py
A fairly straightforward macro/hotkey program for Adafruit MACROPAD.
Macro key setups are stored in the /macros folder (configurable below),
load up just the ones you're likely to use. Plug into computer's USB port,
use dial to select an application macro set, press MACROPAD keys to send
key sequences.
# pylint: disable=import-error, unused-import, too-few-public-methods
import os
import displayio
import terminalio
from adafruit_display_shapes.rect import Rect
from adafruit_display_text import label
from adafruit_macropad import MacroPad
# CONFIGURABLES ------------------------
MACRO_FOLDER = '/macros'
# CLASSES AND FUNCTIONS ----------------
class App:
    """ Class representing a host-side application, for which we have a set
        of macro sequences. Project code was originally more complex and
        this was helpful, but maybe it's excessive now?"""
    def __init__(self, appdata):
        self.name = appdata['name']
        self.macros = appdata['macros']
    def switch(self):
        """ Activate application settings; update OLED labels and LED
            colors. """
        group[13].text = self.name   # Application name
        for i in range(12):
            if i < len(self.macros): # Key in use, set label + LED color
                macropad.pixels[i] = self.macros[i][0]
                group[i].text = self.macros[i][1]
            else:  # Key not in use, no label or LED
                macropad.pixels[i] = 0
                group[i].text = ''
        macropad.keyboard.release_all()
        macropad.pixels.show()
        macropad.display.refresh()
# INITIALIZATION -----------------------
macropad = MacroPad()
macropad.display.auto_refresh = False
macropad.pixels.auto_write = False
# Set up displayio group with all the labels
group = displayio.Group()
for key_index in range(12):
    x = key_index % 3
    y = key_index // 3
    group.append(label.Label(terminalio.FONT, text='', color=0xFFFFFF,
                             anchored_position=((macropad.display.width - 1) * x / 2,
                                                macropad.display.height - 1 -
                                                (3 - y) * 12),
                             anchor_point=(x / 2, 1.0)))
group.append(Rect(0, 0, macropad.display.width, 12, fill=0xFFFFFF))
group.append(label.Label(terminalio.FONT, text='', color=0x000000,
                         anchored_position=(macropad.display.width//2, -2),
                         anchor_point=(0.5, 0.0)))
macropad.display.show(group)
# Load all the macro key setups from .py files in MACRO_FOLDER
apps = []
files = os.listdir(MACRO_FOLDER)
files.sort()
for filename in files:
    if filename.endswith('.py'):
        try:
            module = __import__(MACRO_FOLDER + '/' + filename[:-3])
            apps.append(App(module.app))
        except (SyntaxError, ImportError, AttributeError, KeyError, NameError,
                IndexError, TypeError) as err:
            pass
if not apps:
    group[13].text = 'NO MACRO FILES FOUND'
    while True:
        pass
last_position = None
last_encoder_switch = macropad.encoder_switch_debounced.pressed
app_index = 0
apps[app_index].switch()
# MAIN LOOP ----------------------------
while True:
    # Read encoder position. If it's changed, switch apps.
    position = macropad.encoder
    if position != last_position:
        app_index = position % len(apps)
        last_position = position
    # Handle encoder button. If state has changed, and if there's a
    # corresponding macro, set up variables to act on this just like
    # the keypad keys, as if it were a 13th key/macro.
    macropad.encoder_switch_debounced.update()
    if encoder_switch != last_encoder_switch:
        last_encoder_switch = encoder_switch
        if len(apps[app_index].macros) < 13:
            continue    # No 13th macro, just resume main loop
        key_number = 12 # else process below as 13th macro
        pressed = encoder_switch
    else:
        event = macropad.keys.events.get()
        if not event or event.key_number >= len(apps[app_index].macros):
            continue # No key events, or no corresponding macro, resume loop
        key_number = event.key_number
        pressed = event.pressed
    # If code reaches here, a key or the encoder button WAS pressed/released
    # and there IS a corresponding macro available for it...other situations
    # are avoided by 'continue' statements above which resume the loop.
    sequence = apps[app_index].macros[key_number][2]
    if pressed:
        if key_number < 12: # No pixel for encoder button
            macropad.pixels[key_number] = 0xFFFFFF
        for item in sequence:
            if isinstance(item, int):
                if item >= 0:
                    macropad.keyboard.press(item)
                else:
                    macropad.keyboard.release(-item)
            else:
                macropad.keyboard_layout.write(item)
    else:
        # Release any still-pressed modifier keys
            if isinstance(item, int) and item >= 0:
                macropad.keyboard.release(item)
            macropad.pixels[key_number] = apps[app_index].macros[key_number][0]
and the Windows Edge Macro, which sits in the macros folder per the project instructions.
as I said in my original post, the macropad works. I can send key commands to perform functions and shortcuts, but I can't sent plain text. In the code above for Edge, I'd have to change
to
(0x000040, 'Private', [Keycode.CONTROL, Keycode.SHIFT, Keycode.N]),
to get a new, private window in either Edge or Chrome. But I can't send something like "test sentence"
Hope this is clear.
Look above this output and see if there is more text with an actual error message.
demsecure
Post by demsecure »
The only place I see the output is the screen of the macropad. I can tell there is some text above, but I have no way to scroll the macropad screen. Is there a way to see the output in an editor like Mu, Thonny or Visual Studio Code?
Oh, OK, sorry, didn't realize you were reading that from the MacroPad OLED screen. It's probably scrolling out of view on that small display.
Yep, can see more by connecting to the serial console. Mu is probably the easiest for this. Just click the "Serial" button in the toolbar at the top. This will open a new window. You can drag that window up so it shows more lines. You should see the same serial output in that window.
demsecure
Post by demsecure »
able to get the output from Mu.
File "code.py", line 141, in <module>
AttributeError: 'NoneType' object has no attribute 'write'
Code done running.
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
Press any key to enter the REPL. Use CTRL-D to reload.
Adafruit CircuitPython 7.0.0-alpha.5 on 2021-07-21; Adafruit Macropad RP2040 with rp2040
if/else code from from code.py that includes line 141:
    if pressed:
                if item >= 0:
                else:
            else:
    else:
line 141 is : macropad.keyboard_layout.write(item)
so looks as if that's where it's failing
code.py in it's entirety:
key sequences.
import os
import displayio
import terminalio
class App:
    def switch(self):
            colors. """
        for i in range(12):
                group[i].text = ''
    x = key_index % 3
    y = key_index // 3
                                                (3 - y) * 12),
apps = []
files.sort()
        try:
            pass
if not apps:
    while True:
        pass
app_index = 0
while True:
    else:
    if pressed:
                if item >= 0:
                else:
            else:
    else:
demsecure
Post by demsecure »
and in looking over the code, I don't see anywhere (either in code.py or test.py) where
"from adafruit_hid.keyboard_layout_us import KeyboardLayoutUS" in imported
