CircuitPython connected to Adafruit io Crashing
by Tom_Henry on Sat Sep 04, 2021 10:11 pm
CircuitPython and Adafruit io: Crashing
I am having a problem with 2 CircuitPython programs crashing after a few hours while connected to Adafruit io. Both of these programs are running on a Raspberry Pi Zero W. One is located in the attic of our house and the other is in our house. I can access both Pi Zeros using the VNC viewer.
For the purposes of this forum I have attached the 2 CircuitPython programs that use slightly different approaches to sending data to Adafruit io. Both programs work error free for a few hours and then crash. Both seem to have the same problem.
They timeout after a few hours. I have the time delay on both where the programs refresh the data every 1 or 2 minutes.
Both programs deliver accurate information to 2 different Adafruit io Dashboards.
I have attached a copy of both CircuitPython programs (pistart2.py and code.py) and a screenshot of one of the Dashboards.
I have copied the first part of the Traceback errors that come after the crashes, see below.
Raspberry Pi Zero W in house
Python Program: pistart2.py
Python 3.7.3 (/usr/bin/python3)
>>> %Run pistart2.py
Here is a sample of the output being printed from the Pi Zero in our house.
The output from the attic sensors is very similar.
Today is Saturday 9/4/2021
The time is 12:01:41
Temperature: 87.4 F
Humidity: 34.3 %
Pressure: 14.6 psi
Altitude = 29.56 meters
Particles 0.3: 4806
Particles 0.5: 1474
Particles 1.0: 334
Particles 2.5: 37
Particles 5.0: 10
Particles 10.0: 8
Crashes after running several hours.
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
Raspberry Pi Zero W in attic
Python Program: code.py
>>> %Run code.py
Crashes after several hours.
I am trying to figure out why this is happening.
Does it have something to do with my time delay?
It seems like there could be a problem with Adafruit io because everything works fine for a few hours and then crashes.
I am open to any suggestions that might help these programs run for days instead of just a few hours.
Thank you,
Tom Henry
Attic Screenshot.png (166.84 KiB) Viewed 80 times
pistart2.py
(5.63 KiB) Not downloaded yet
code.py
(7.78 KiB) Not downloaded yet
Tom_Henry
Re: CircuitPython connected to Adafruit io Crashing
by brubell on Tue Sep 07, 2021 9:04 am
Could be a DNS resolution error. Are you able to try connecting the Pi to another network?
brubell
by Tom_Henry on Tue Sep 07, 2021 12:51 pm
I have a Metro ESP32-S2 Express also crashing after a few hours while connected to Adafruit io.
Not sure what DNS Resolution is but can you recommend an easy to connect to other network that I can try out?
I really like using Adafruit io as I have a good understanding of its various parts and how it works.
I have attached a copy of the CircuitPython code I am using with the Metro ESP32-S2.
Thank you,
Tom Henry
code.py
(7.79 KiB) Not downloaded yet
Tom_Henry
by Tom_Henry on Wed Sep 08, 2021 10:18 pm
by brubell on Tue Sep 07, 2021 2:04 pm
I was able to connect my PyPortal to another network using a CircuitPython project from John Park called Air Quality Display. As you can see from the attached code.py, it accesses airnowapi.org.
Here is the crash after some ok responses:
Retrieving data...Reply is OK!
Response is 68
Response is 68
Retrieving data...Traceback (most recent call last):
File "code.py", line 61, in <module>
File "code.py", line 45, in <module>
File "adafruit_pyportal/__init__.py", line 306, in fetch
File "adafruit_portalbase/network.py", line 479, in fetch
File "adafruit_requests.py", line 698, in get
File "adafruit_requests.py", line 580, in request
OutOfRetries: Repeated socket failures
Does that help understand what might be causing my crashes?
Thank you,
Tom Henry
code.py
(2.4 KiB) Downloaded 1 time
Tom_Henry
by brubell on Fri Sep 10, 2021 9:49 am
Not sure, moved to the CircuitPython forum to see if there's someone else who would know.
brubell
by subether on Thu Sep 16, 2021 10:51 pm
I'd like to add that I'm having a similar problem with the magtag and MatrixPortals; the connections are intermittent and do not seem to work all the time.
Getting time for timezone America/Phoenix
  File "code.py", line 106, in <module>
  File "adafruit_portalbase/__init__.py", line 411, in get_local_time
  File "adafruit_portalbase/network.py", line 231, in get_local_time
  File "adafruit_portalbase/network.py", line 214, in get_strftime
  File "adafruit_portalbase/network.py", line 200, in get_strftime
  File "adafruit_requests.py", line 556, in request
  File "adafruit_requests.py", line 423, in _get_socket
RuntimeError: Sending request failed
Is there a way within circuitpython to connect to a standard ntp server (Say, pool.ntp.org) to get the time?
subether
by Tom_Henry on Sat Sep 18, 2021 6:00 pm
There is probably as way to get the date and time from the internet but
I have been using Adafruit's PCF8523 Real Time Clock with the STEMMA QT / Qwiic connectors, part # 5189.
It only costs $5. I bought several of them and use them on my CirucuitPython projects for the Raspberry Pi 4 or Zero or Feathers with AirLift WiFi.
You can go to this Adafruit url and it gives you the CircuitPython code you need to add to your program: https://learn.adafruit.com/adafruit-pcf ... cuitpython
The PCF8523 has a small CR1220 battery so once you set the date and time you can move it from project to project and not have to worry about resetting the date and time.
Here is the output I get out of a typical set up with a sensor:
Tom Henry's MS8607 Sensor Data:
Today is Saturday: 9/18/2021
The time is 14:58:08
Pressure: 1011.25 hPa
Pressure: 14.68 psi
Temperature: 24.78 C
Temperature: 75.93 F
Humidity: 51.00 % rH
This came from Adafruit's MS8607 sensor.
Tom Henry
Tom_Henry
