circuitpython DIY air quality monitor problem
by RoyBob on Mon Sep 27, 2021 8:57 am
I am building your diy-air-quality-monitor project and am in the section called "connect to wifi". I am using cryptopython 7.0.0 and the examples set 7.x (This zip was downloaded from https://learn.adafruit.com/adafruit-air ... et-connect on September 21, 2021). When trying to run the code, I get the following error:
code.py output:
ESP32 SPI webclient test
File "code.py", line 50, in <module>
File "adafruit_esp32spi/adafruit_esp32spi.py", line 335, in status
File "adafruit_esp32spi/adafruit_esp32spi.py", line 324, in _send_command_get_response
File "adafruit_esp32spi/adafruit_esp32spi.py", line 238, in _send_command
RuntimeError: ESP32 timed out on SPI select
I can't seem to get past this point. Could you please help me with this
RoyBob
Re: circuitpython DIY air quality monitor problem
by adafruit_support_carter on Tue Sep 28, 2021 1:11 pm
Did you download the zip using the Download Project Bundle button?
by RoyBob on Wed Sep 29, 2021 8:55 am
Yes I did download the bundle and moved the files to the circuitpy folder. I have just repeated the procedure, and received the same error message.
RoyBob
by adafruit_support_carter on Wed Sep 29, 2021 12:23 pm
Is your hardware setup the same as the air quality guide? Feather M4 Express + AirLift FeatherWing? (or, if not, what?) We'll try and duplicate the error here, matching your setup.
by RoyBob on Thu Sep 30, 2021 8:45 am
Yes, my hardware setup is the same as the air quality guide with the exception of the "FeatherWing Doubler board" which was unavailable at the time. I used 2 "FeatherWing Proto boards" with the 3v and ground connected, and checked with a voltmeter.
RoyBob
by RoyBob on Sat Oct 16, 2021 1:02 pm
I have managed to purchase a "FeatherWing Doubler board" , and I no longer receive he error when running the code. Thanks for the help.
RoyBob
