74HC595 library and RPi Pico
by cheeseshark on Wed Oct 13, 2021 9:26 pm
Is there any documentation out there that explains the use of the adafruit_74HC595 library with the Raspberry Pi Pico with Circuitpython?
The existing example on this site use board references that don't exist on the Pico (board.SPI).
import time
import board
import digitalio
import adafruit_74hc595
latch_pin = digitalio.DigitalInOut(board.D5)
sr = adafruit_74hc595.ShiftRegister74HC595(board.SPI(), latch_pin)
Thanks in advance
Mike
cheeseshark
Re: 74HC595 library and RPi Pico
by kattni on Thu Oct 14, 2021 1:47 pm
Hello Mike,
board.SPI() is a board-specific object available in the board module for many CircuitPython boards. It takes the place of using busio and providing it a clock pin and data pin.
To use it on the Pico with SPI, you would do the following along with the rest of your code, replacing clock_pin and data_pin with the pins you connected to on the Pico.
import board
import busio
spi = busio.SPI(board.clock_pin, board.data_pin)
Here is an example of what it might look like:
import board
import busio
spi = busio.SPI(clock=board.GP2, MOSI=board.GP3, MISO=board.GP4)
Then, you change the current example's board.SPI() to be the spi object created above, and it should work.
Hopefully this helps.
kattni
by cheeseshark on Thu Oct 14, 2021 4:34 pm
Thanks for the information. I'll give it a try when I get home.
cheeseshark
